Delete/Purge old plugins [message #332816] |
Mon, 10 November 2008 12:44  |
Hi!
Is there a way to delete all plugins from the eclipse installation which
have been replaced by newer versions? Google did not come up with anything
useful apart from deleting them manually.
Florian
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: Delete/Purge old plugins [message #332834 is a reply to message #332830] |
Mon, 10 November 2008 17:10   |
Originally posted by: zx.code9.com
Eric Rizzo wrote:
> On 11/10/2008 12:44 PM, DI Florian Hackenberger wrote:
>> Hi!
>> anything
> No, manual is the only way.
> By the way, the old versions are kept around for good reasons, so you
> may not want to go deleting them. For example, to enable the feature
> that lets you revert to a previous configuration in the case that your
> current one gets broken. Also, plugins can specify that they require a
> specific version range of other plugins, so it is quite possible that
> older versions need to be kept around to satisfy other plugins.
In Eclipse 3.4, this has changed with p2 and its GC. By default,
plug-ins who have no dependents will be GC'd.
~ Chris
Re: Delete/Purge old plugins [message #332866 is a reply to message #332834] |
Tue, 11 November 2008 11:37  |
On 11/10/2008 5:10 PM, Chris Aniszczyk wrote:
>>> Hi!
>>> anything
Cool. But I'm curious how the "revert configuration" feature can work if
old plug-ins are removed. Would that scenario trigger re-download of the
GCed plug-ins?
Eric
FUDForum. Page generated in 0.03665 seconds
