Home » Eclipse Projects » Eclipse Platform » WizardDialog default button
WizardDialog default button [message #332810] Mon, 10 November 2008 11:24 Go to next message
Is there any way, from my Wizard class, to remove the "default button"
designation from the WizardDialog's "Finish" button? I need to
circumvent the behavior of the wizard doing its finish work when the
Enter key is pressed.
Thanks in advance,
Eric
Re: WizardDialog default button [message #332812 is a reply to message #332810] Mon, 10 November 2008 11:44 Go to previous messageGo to next message
IWizardContainer container = wizard.getContainer();
Shell shell = container.getShell();
shell.setDefaultButton(null);
Remy
Re: WizardDialog default button [message #332822 is a reply to message #332812] Mon, 10 November 2008 15:37 Go to previous messageGo to next message
Remy,
I already looked at that, but the comments for setDefaultButton() say:
* If the argument is not null, sets the receiver's default
* button to the argument, and if the argument is null, sets
* the receiver's default button to the first button which
* was set as the receiver's default button (called the
* <em>saved default button</em>).
Since the default button is set by WizardDialog, it can't be set back to
null. Worse, WizardDialog has code that explicitly sets the default
button whenever a page is re-validated - arrrrgh!
Eric
Re: WizardDialog default button [message #332844 is a reply to message #332822] Tue, 11 November 2008 02:38 Go to previous messageGo to next message
Ah, sorry about that.
I guess the only way around it is to subclass WizardDialog. But I
presume your wizards are being constructed by the framework (through the
'File' menu) so that's probably a no-go.
Remy
Re: WizardDialog default button [message #334733 is a reply to message #332822] Wed, 25 February 2009 10:37 Go to previous message
Eric, we faced the same problem today on IRC, and we looked at the code.
If set to null, it actually apparently works so the API looks wrong here
(or there is a bug in the code).
So the fix here is to subclass DialogWizard, override updateButtons in
WizardDialog and do getShell().setDefaultButton(null);
It only works if you are in control when creating the DialogWizard.
Antoine
Previous Topic:Eclipse Plugin - Read from file
Next Topic:String Externalization/Localization/I18N Tools
Current Time: Sun Oct 19 14:25:51 EDT 2025
Powered by FUDForum. Page generated in 0.04555 seconds
