Home » Eclipse Projects » Eclipse Platform » What makes a package be a package (and not a folder)?
What makes a package be a package (and not a folder)? [message #332750] Fri, 07 November 2008 10:08 Go to next message
What makes a package be a package? When checking the sources of a projekt
in filesystem each package (that I see in the package explorer) is basicly
a folder in the filesystem. Currently I have the problem, that I've a
imported project where the source folders children are are handled as
folders and not as packages as they should. As a result the plugin is not
working :(
Any Ideas?
Re: What makes a package be a package (and not a folder)? [message #332754 is a reply to message #332750] Fri, 07 November 2008 10:34 Go to previous messageGo to next message
Jan,
If you look at the Properties... of a project, and look at the Java
Build Path's Source tab, you'll see that here you can specify which
folders acts as roots for packages.
Jan Kohnert wrote:
> Hello,
> projekt in filesystem each package (that I see in the package
> explorer) is basicly a folder in the filesystem. Currently I have the
> problem, that I've a imported project where the source folders
> children are are handled as folders and not as packages as they
> should. As a result the plugin is not working :(
> Any Ideas?
Re: What makes a package be a package (and not a folder)? [message #332758 is a reply to message #332754] Fri, 07 November 2008 10:48 Go to previous messageGo to next message
Something must be really wrong with my plugin :(
I don'nt eaven have a buildpath option in the Properties. If I right click
the plugin in package explorer the entry 'Build Path' says 'No actions
available'
Re: What makes a package be a package (and not a folder)? [message #332760 is a reply to message #332758] Fri, 07 November 2008 10:51 Go to previous messageGo to next message
Jan,
It is even a Java project? I.e., is the little "J" in the upper right
corner? I'm not sure there's a way to convert a project to a Java
project once it exists. Best to create the right type of project and
then copy the rest into that...
> click the plugin in package explorer the entry 'Build Path' says 'No
> actions available'
Re: What makes a package be a package (and not a folder)? [message #332764 is a reply to message #332760] Fri, 07 November 2008 11:03 Go to previous messageGo to next message
Ed,
No there is no 'J' :(
I've created this project as java project on one machine. I shared it
using SVN and exportet it to another machine. Somehow I mus have missed
something important. It seems something defines a java project. And it
seems that I must have forgotten to share that 'thing'.
Thank you for your help Ed. It is allways impressive how fast you keep
answering questions and how anxious your are!
Jan Kohnert
Re: What makes a package be a package (and not a folder)? [message #332768 is a reply to message #332764] Fri, 07 November 2008 11:32 Go to previous messageGo to next message
You might be able to just edit the .project file (use the navigator view
to see it) and add the Java nature:
<natures>
<nature>org.eclipse.pde.PluginNature</nature>
<nature>org.eclipse.jdt.core.javanature</nature>
</natures>
Just create a new Java project to see what the default java contents are.
-Andrew
Jan Kohnert wrote:
> Ed,
> Jan Kohnert
Re: What makes a package be a package (and not a folder)? [message #332772 is a reply to message #332764] Fri, 07 November 2008 12:53 Go to previous messageGo to next message
Jan,
I faced a similar problem. I copied project from one system to another
using a shared folder. When i finished importing project onto the new
workspace, there was no package structure rather just a folder structure
was displayed in the package explorer.
To fix this i used the PDE Tools -> update classpath option by right
clicking on the project in package explorer. This solved it for me.
- Chetan Kumar
Re: What makes a package be a package (and not a folder)? [message #332774 is a reply to message #332764] Fri, 07 November 2008 13:39 Go to previous messageGo to next message
Jan,
Note the other comments about the .project file... It's important that
the .classpath and .project files are also checked into SVN. You can
unfilter .* resource so you'll see them in the navigator/explorer...
Jan Kohnert wrote:
> Ed,
> missed something important. It seems something defines a java project.
> And it seems that I must have forgotten to share that 'thing'.
> Jan Kohnert
Re: What makes a package be a package (and not a folder)? [message #332784 is a reply to message #332774] Fri, 07 November 2008 17:36 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
And in addition is important that the .settings folder is also checked
into SVN. That's the only way that the project is sure to look and act
the same on everyone's system.
Ed Merks wrote:
> Jan,
Rich Kulp
Previous Topic:project.create() and nature configuration
Next Topic:Generalizing CellEditor
Current Time: Fri Nov 07 20:53:04 EST 2025
Powered by FUDForum. Page generated in 0.04671 seconds
