Home » Eclipse Projects » Eclipse Platform » [DataBinding] Problem with 2 different class model in a TreeViewer
[DataBinding] Problem with 2 different class model in a TreeViewer [message #332707] Thu, 06 November 2008 06:27 Go to next message
Originally posted by: filippo.c.evinco.it
I've a TreeViewer where the root nodes are of class Person and all leaf
are of class Email:
-person1
---email1
---email2
---email3
-person2
---email1
---email2
where:
Person have 3 properties : String name String surname ArrayList<Email> email
and Email have 1 property : String address
I have a composite with 3 Text : nameText surnameText addressText
When i select a person in the Tree i want bind name and surname on
nameText and surnameText and when i select email bind address on
addressText.
This is my code:
IObservableValue selection = ViewersObservables.observeSingleSelection(treeview);
selection.addChangeListener(new IChangeListener(){
public void handleChange(ChangeEvent event) {
IViewerObservableValue observable = (IViewerObservableValue)event.getSource();
Object obj = observable.getValue();
if(obj instanceof Person){
bindingContext.removeBinding(address);
bindingContext.addBinding(name);
bindingContext.addBinding(surname);
bindingContext.dispose();
}else if(obj instanceof Email){
bindingContext.removeBinding(name);
bindingContext.removeBinding(surname);
bindingContext.addBinding(address);
//v is the view where are the Text and getters method return Texts
name = bindingContext.bindValue(SWTObservables.observeText(v.getNam eText(),SWT.Modify),
BeansObservables.observeDetailValue(Realm.getDefault(), selection, "name",String.class)
,null,null);
surname = bindingContext.bindValue(SWTObservables.observeText(v.getSur nameText(),SWT.Modify),
BeansObservables.observeDetailValue(Realm.getDefault(), selection, "surname",String.class),
null,null);
address = bindingContext.bindValue(SWTObservables.observeText(v.getAdd ressText(),SWT.Modify),
BeansObservables.observeDetailValue(Realm.getDefault(), selection, "address",String.class),
null,null);
When i select a person i have this error: "Could not find property with name address in class class databindingprova.model.Person".
Re: [DataBinding] Problem with 2 different class model in a TreeViewer [message #332708 is a reply to message #332707] Thu, 06 November 2008 07:20 Go to previous messageGo to next message
This is a know "problem" or just works by as designed currently. You
can't mix class types.
The bugzilla you are interested in is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247997
Tom
filippo schrieb:
> Hi
> are of class Email:
> -person1
> ---email1
> ---email2
> ---email3
> -person2
> ---email1
> ---email2
> where:
> email
> addressText.
> This is my code:
> name =
> ,null,null);
> surname =
> null,null);
> address =
> null,null);
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [DataBinding] Problem with 2 different class model in a TreeViewer [message #332740 is a reply to message #332707] Fri, 07 November 2008 02:50 Go to previous messageGo to next message
see question below.
Why do you dispose the context after adding or removing bindings?
Regards, Sebastian
Re: [DataBinding] Problem with 2 different class model in a TreeViewer [message #332742 is a reply to message #332740] Fri, 07 November 2008 03:37 Go to previous message
Cause adding and removing bindings seems have not effect in DataBindingContext. In effect dispose is not a solution.
Sebastian Paul ha scritto:
> Hi
> see question below.
> Regards, Sebastian
Previous Topic:needs help to setup our org.eclipse.ui.navigator.navigatorContent
Next Topic:Extension point problem
Current Time: Fri Nov 21 17:20:23 EST 2025
Powered by FUDForum. Page generated in 0.18753 seconds
