Home » Eclipse Projects » Eclipse Platform » [p2]Using links file in Eclipse 3.4
[p2]Using links file in Eclipse 3.4 [message #332669] Tue, 04 November 2008 10:01 Go to next message
I am trying to add a feature to Eclipse 3.4 using links mechanism.
The folder I am trying to add is having a feature with two different
versions. Similarly the plug-ins folder also has two sets of same plug-ins
with different versions corresponding to the two features (same feature of
two different versions).
On starting Eclipse 3.4, with a link file in links folder pointing to the
above mentioned setup, latest version of the feature is getting loaded,
but some of the plug-ins of older version are getting loaded. The set of
plug-ins getting loaded with older version is not consistent every time I
restart eclipse with clean option.
The same setup works fine with older version of Eclipse.
Is the setup mentioned above a valid one in Eclipse 3.4? Can I explicitly
specify Eclipse to load a certain version of plug-ins?
Re: [p2]Using links file in Eclipse 3.4 [message #332694 is a reply to message #332669] Wed, 05 November 2008 09:01 Go to previous message
If you don't get good response here, try posting to the
eclipse.technology.equinox group.
> plug-ins with different versions corresponding to the two features (same
> feature of two different versions).
> the above mentioned setup, latest version of the feature is getting
> loaded, but some of the plug-ins of older version are getting loaded.
> The set of plug-ins getting loaded with older version is not consistent
> every time I restart eclipse with clean option.
> explicitly specify Eclipse to load a certain version of plug-ins?
Previous Topic:[p2] Works... the second time
Next Topic:rcp application and file association
Current Time: Sun Jul 27 22:53:08 EDT 2025
Powered by FUDForum. Page generated in 0.03431 seconds
