Home » Eclipse Projects » Eclipse Platform » Headless build fails to fine imported package.
Headless build fails to fine imported package. [message #332654] Mon, 03 November 2008 15:52 Go to next message
I have a product that builds fine when I export it via the product
export wizard. When I build that same product using the headless
build, I get a compile error that an imported package can't be found.
The package depencency is specified by using import package instead of
require bundle (and no, I can't switch it to require bundle). Any
ideas on how to fix this? Could this be a bug?
Bryan
Re: Headless build fails to fine imported package. [message #332676 is a reply to message #332654] Tue, 04 November 2008 11:22 Go to previous messageGo to next message
Import-Package should work just fine. The problem is likely that the
bundle providing the package is not being considered by the build, or
did not resolve. Make sure the bundle is present in your baseLocation,
or buildDirectory. The build output should contain warnings if some
bundles did not resolve.
-Andrew
> export wizard. When I build that same product using the headless build,
> I get a compile error that an imported package can't be found. The
> require bundle (and no, I can't switch it to require bundle). Any ideas
> Bryan
Re: Headless build fails to fine imported package. [message #332677 is a reply to message #332676] Tue, 04 November 2008 11:38 Go to previous message
The log file shows that the bundle containing the exported package was
built (even before the bundles that depend on it).
Bryan
> -Andrew
>> Bryan
Previous Topic:Access restriction problem when using Java 6
Next Topic:How to implement a MessageDialog
Current Time: Sun Aug 31 08:55:12 EDT 2025
Powered by FUDForum. Page generated in 0.05111 seconds
