Home » Eclipse Projects » Eclipse Platform » Access restriction problem when using Java 6
| Access restriction problem when using Java 6 [message #332651] |
Mon, 03 November 2008 12:58  |
I am getting access restrictions errors against JAXB (javax.xml.bind...)
classes when using Java 6; all is fine with Java 5. I have a wrapped library
bundle for JAXB that with Java 5 fulfils the dependency. But since JAXB is
bundled with Java 6 and javax.xml.bind is not on the rt.jar access rules as
"accessible" the errors appear; even though the wrapped bundle is still the
dictated dependency.
This seems an odd way for Eclipse to handle the situation, is it typical, is
this a bug or am I simply doing something dumb?
Btw, I know that I can shut off the errors in the compiler settings, but
that is quite coarse grained and cover up real problems. And yes I could
down grade the errors to warnings and than add
@SuppressWarnings("restriction"), but that would require going through 1000+
warnings and this would all be lost the next time I processed with JAXB.
Any suggestions?
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme & ORMF
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf/]
| Re: Access restriction problem when using Java 6 [message #332670 is a reply to message #332651] |
Tue, 04 November 2008 10:09   |
Hi Joel,
one hint: as of Eclipse/Equinox 3.3 the javax package is no longer
accessible by default. You have to add someting like
"Import-Package: javax.xml.bind.<your-package>"
to the MANIFEST.MF in your bundle.
I can't find the bunch of URL we've collected when we where hit by
this problem, but there are quite a few. Just look for something
containing "strict mode equinox" or "boot delegation" on your favorite
search engine.
Achim
On Mon, 03 Nov 2008 17:58:18 +0000, Joel Rosi-Schwartz
<Joel.Rosi-Schwartz@Etish.org> wrote:
>Hi,
>Any suggestions?
>Thanks,
>Joel
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
| Re: Access restriction problem when using Java 6 [message #332674 is a reply to message #332670] |
Tue, 04 November 2008 10:50   |
Achim,
Thanks for that, but this does not seem to help. Michael, as Achim has
already been through this, possibly he can take a look at your JAXB and
fileaccess plug-ins to see if he has any idea.
I am going to pass this back to you Michael, as it does not make sense for
me to be focusing on this at the moment. Let me know if I can assist though.
Joel
On 04/11/2008 15:09, in article 4pn0h4pnuu94r5nl7gelpa2b29etd3odfs@4ax.com,
"Achim Lörke" <Achim.Loerke@bredex.de> wrote:
> Hi Joel,
> search engine.
> Achim
>> Any suggestions?
>> Thanks,
>> Joel
> Achim
| Re: Access restriction problem when using Java 6 [message #332675 is a reply to message #332674] |
Tue, 04 November 2008 11:22  |
Originally posted by: zx.code9.com
Joel Rosi-Schwartz wrote:
> Achim,
Joel, feel free to find me on Skype and we can chat about this problem a
bit. I think the solution is to just add access rules to the JRE
container and your problem will be solved in both cases.
~ Chris
Current Time: Sat Nov 08 08:42:35 EST 2025
Powered by FUDForum. Page generated in 0.03225 seconds
