Home » Eclipse Projects » Eclipse Platform » tableviewer error on events ... eclipse 3.3.2
tableviewer error on events ... eclipse 3.3.2 [message #332629] Mon, 03 November 2008 05:14 Go to next message
Hi all
I'm having a weird problem with my table viewer .
Based on a selection event (the selection comes from a different view) . the
table view is populated with a list of objects. .
Usually it works but there is an object that generates this error ... what
am I doing wrong?
org.eclipse.jface.viewers.CustomHashtable.hashCode(CustomHas htable.java:264)
at org.eclipse.jface.viewers.CustomHashtable.get(CustomHashtabl e.java:236)
org.eclipse.jface.viewers.StructuredViewer.mapElement(Struct uredViewer.java:1243)
org.eclipse.jface.viewers.StructuredViewer.associate(Structu redViewer.java:605)
org.eclipse.jface.viewers.AbstractTableViewer$1.handleEvent( AbstractTableViewer.java:83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Table.checkData(Table.java:811)
at org.eclipse.swt.widgets.Table.wmNotifyChild(Table.java:5882)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:261)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:189)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.widgets.Table.windowProc(Table.java:5025)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at com.xxx.workbench.application.Application.start(Application. java:75)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: tableviewer error on events ... eclipse 3.3.2 [message #332630 is a reply to message #332629] Mon, 03 November 2008 05:27 Go to previous messageGo to next message
What's the content around line CustomHashtable 264? Looks like you are
inserting an NULL value and TableViewer can't deal with null-references.
Tom
Kar schrieb:
> Hi all
> the table view is populated with a list of objects. .
> what am I doing wrong?
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: tableviewer error on events ... eclipse 3.3.2 [message #332631 is a reply to message #332629] Mon, 03 November 2008 05:38 Go to previous messageGo to next message
debugging I have seen what follows:
table viewer structured content provider ...
getElements
-- returns 4 objects not null ...
with the debug I stop in this place ...
TableViewer(StructuredViewer).associate (Object element, Item item)
where
element = null
Item = TableItem {}
"Kar" <carmeloscala@hotmail.com> wrote in message
news:gemitc$b7u$1@build.eclipse.org...
> Hi all
> am I doing wrong?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332632 is a reply to message #332630] Mon, 03 November 2008 05:41 Go to previous messageGo to next message
Hi Tom
error removed ... but still don't understand why
I was using the type SWT.VIRTUAL creating the table ...
TableViewer viewer = new TableViewer(parent, SWT.H_SCROLL | SWT.V_SCROLL |
SWT.BORDER
| SWT.FULL_SELECTION | SWT.MULTI);
Removing virtual I don't see the error anymore ...
why?
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gemjn0$f4l$1@build.eclipse.org...
> Tom
> Kar schrieb:
>> Hi all
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: tableviewer error on events ... eclipse 3.3.2 [message #332633 is a reply to message #332632] Mon, 03 November 2008 05:58 Go to previous messageGo to next message
Maybe because there is/was a bug in 3.3.2? We fixed some
Virtual-Problems in 3.4.
Tom
Kar schrieb:
> Hi Tom
> | SWT.BORDER
> why?
>> Tom
>> Kar schrieb:
>>> Hi all
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332634 is a reply to message #332633] Mon, 03 November 2008 06:07 Go to previous messageGo to next message
I believe there is still some problem with the list of item I'm passing to
the table viewer ...
the same list that was giving me problem before (that works removing the
virtual attribute) now is giving me problem when a new input is set in the
viewer ...
just to be clear ...
the table viewer has got the list of item that was generating the error
before:
now when I select a new input I get this error (and again ... I can see that
he is trying to disassociate a null element)
where should I look ... for sure the items in the list ARE NOT NULL ...
can it be some problem due to object hash????
thanks
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
org.eclipse.jface.viewers.StructuredViewer.disassociate(Stru cturedViewer.java:618)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:711)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:633)
org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:620)
org.eclipse.jface.viewers.AbstractTableViewer$2.run(Abstract TableViewer.java:576)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1368)
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1330)
org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(A bstractTableViewer.java:574)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1606)
news:gemlgk$rs5$1@build.eclipse.org...
> Tom
> Kar schrieb:
>> Hi Tom
>> | SWT.BORDER
>> why?
>>> Tom
>>> Kar schrieb:
>>>> Hi all
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Method)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332635 is a reply to message #332634] Mon, 03 November 2008 06:23 Go to previous messageGo to next message
Tom sorry to bother but could u tell me (if u know) the bit of code that
creates the TableItem when I set the input to the view ...
just to see if something is doing wrong during the creation ...
this think is driving me crazy ...
in the mean time I will try do debug the setinput (of the wrong list) and
see if everything is correct ...
thanks
news:gemm0t$1m7$1@build.eclipse.org...
> viewer ...
> before:
> that he is trying to disassociate a null element)
> thanks
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Tom
>> Kar schrieb:
>>> Hi Tom
>>> | SWT.BORDER
>>> why?
>>>> null-references.
>>>> Tom
>>>> Kar schrieb:
>>>>> Hi all
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Method)
>>>>> Method)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332636 is a reply to message #332635] Mon, 03 November 2008 06:35 Go to previous messageGo to next message
Does your Model object overload #hashCode? The hashCode has to be stable
and not change.
Tom
> and see if everything is correct ...
> thanks
>> passing to the table viewer ...
>> the virtual attribute) now is giving me problem when a new input is
>> set in the viewer ...
>> error before:
>> see that he is trying to disassociate a null element)
>> thanks
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Tom
>>> Kar schrieb:
>>>> Hi Tom
>>>> SWT.V_SCROLL
>>>> | SWT.BORDER
>>>> why?
>>>>> null-references.
>>>>> Tom
>>>>> Kar schrieb:
>>>>>> Hi all
>>>>>> view) .
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Method)
>>>>>> Method)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332638 is a reply to message #332636] Mon, 03 November 2008 07:33 Go to previous messageGo to next message
no :-(
news:gemnm3$cfc$1@build.eclipse.org...
> and not change.
> Tom
>> thanks
>>> error before:
>>> thanks
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Tom
>>>> Kar schrieb:
>>>>> Hi Tom
>>>>> SWT.V_SCROLL
>>>>> | SWT.BORDER
>>>>> why?
>>>>>> are
>>>>>> null-references.
>>>>>> Tom
>>>>>> Kar schrieb:
>>>>>>> Hi all
>>>>>>> view) .
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332639 is a reply to message #332636] Mon, 03 November 2008 07:48 Go to previous messageGo to next message
I don't know if this can helps ... but sure this is the problem ...
when I create the table view I pass an array of 4 items ...
when I set the new input and the setinput code start I can see this ...
abstract table viewer ... items = doGetItems () ... the items already in the
table
[TableItem { New file.xml}, TableItem { New Text Document.txt}, TableItem
{ privileges.cfg}, TableItem { prova.txt}, TableItem {}, TableItem {},
TableItem {}, TableItem {}, TableItem {}, TableItem {}, TableItem {},
TableItem {}, TableItem {}, TableItem {}, TableItem {}]
why have I got all this tableitem empty ...
the error appears when hi tries to remove the items beyond the end of the
selection ...
// dispose of all items beyond the end of the current elements
if (min < items.length) {
for (int i = items.length; --i >= min;) {
disassociate(items[i]);
if (virtualManager != null) {
virtualManager.removeIndicesFromTo(min, items.length - 1);
> and not change.
> Tom
>> thanks
>>> error before:
>>> thanks
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Tom
>>>> Kar schrieb:
>>>>> Hi Tom
>>>>> SWT.V_SCROLL
>>>>> | SWT.BORDER
>>>>> why?
>>>>>> are
>>>>>> null-references.
>>>>>> Tom
>>>>>> Kar schrieb:
>>>>>>> Hi all
>>>>>>> view) .
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
Re: tableviewer error on events ... eclipse 3.3.2 [message #332640 is a reply to message #332638] Mon, 03 November 2008 08:02 Go to previous message
I have been following with the debug the creation of the view when I add the
input that gives me problem ...
Table viewer Abstract table viewer ... interalrefresh all ...
it just gets 4 items ... and for what I'm seeing except the already present
item in the view it is just creating up to the number of item I need
for (int i = min; i < children.length; ++i) {
createItem(children[i], i);
[ children.length ==4 ]
but who knows why ... when I do set the input again ... the doGetItems gives
me back the array with 25 items I sent before ...
news:gemr36$bdl$1@build.eclipse.org...
> no :-(
>> and not change.
>> Tom
>>> thanks
>>>> error before:
>>>> thanks
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Tom
>>>>> Kar schrieb:
>>>>>> Hi Tom
>>>>>> SWT.V_SCROLL
>>>>>> | SWT.BORDER
>>>>>> why?
>>>>>>> are
>>>>>>> null-references.
>>>>>>> Tom
>>>>>>> Kar schrieb:
>>>>>>>> Hi all
>>>>>>>> view) .
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Method)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Method)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
Previous Topic:[DataBinding] AssertionFailedException: "null argument" when using DataBindingContext's de
Next Topic:[ActivityMgmt] Infinite loop stemming from MutableActivityManager
Current Time: Wed Oct 29 11:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.08803 seconds
