tableviewer error on events ... eclipse 3.3.2 [message #332629] |
Mon, 03 November 2008 05:14  |
Hi all
I'm having a weird problem with my table viewer .
Based on a selection event (the selection comes from a different view) . the
table view is populated with a list of objects. .
Usually it works but there is an object that generates this error ... what
am I doing wrong?
org.eclipse.jface.viewers.CustomHashtable.hashCode(CustomHas htable.java:264)
at org.eclipse.jface.viewers.CustomHashtable.get(CustomHashtabl e.java:236)
org.eclipse.jface.viewers.StructuredViewer.mapElement(Struct uredViewer.java:1243)
org.eclipse.jface.viewers.StructuredViewer.associate(Structu redViewer.java:605)
org.eclipse.jface.viewers.AbstractTableViewer$1.handleEvent( AbstractTableViewer.java:83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Table.checkData(Table.java:811)
at org.eclipse.swt.widgets.Table.wmNotifyChild(Table.java:5882)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:261)
at org.eclipse.swt.widgets.Table.callWindowProc(Table.java:189)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.widgets.Table.windowProc(Table.java:5025)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at com.xxx.workbench.application.Application.start(Application. java:75)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: tableviewer error on events ... eclipse 3.3.2 [message #332639 is a reply to message #332636] |
Mon, 03 November 2008 07:48   |
I don't know if this can helps ... but sure this is the problem ...
when I create the table view I pass an array of 4 items ...
when I set the new input and the setinput code start I can see this ...
abstract table viewer ... items = doGetItems () ... the items already in the
table
[TableItem { New file.xml}, TableItem { New Text Document.txt}, TableItem
{ privileges.cfg}, TableItem { prova.txt}, TableItem {}, TableItem {},
TableItem {}, TableItem {}, TableItem {}, TableItem {}, TableItem {},
TableItem {}, TableItem {}, TableItem {}, TableItem {}]
why have I got all this tableitem empty ...
the error appears when hi tries to remove the items beyond the end of the
selection ...
// dispose of all items beyond the end of the current elements
if (min < items.length) {
for (int i = items.length; --i >= min;) {
disassociate(items[i]);
if (virtualManager != null) {
virtualManager.removeIndicesFromTo(min, items.length - 1);
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gemnm3$cfc$1@build.eclipse.org...
> Does your Model object overload #hashCode? The hashCode has to be stable
> and not change.
> Tom
> Kar schrieb:
>> Tom sorry to bother but could u tell me (if u know) the bit of code that
>> creates the TableItem when I set the input to the view ...
>> just to see if something is doing wrong during the creation ...
>> this think is driving me crazy ...
>> in the mean time I will try do debug the setinput (of the wrong list)
>> and see if everything is correct ...
>> thanks
>> "Kar" <carmeloscala@hotmail.com> wrote in message
>> news:gemm0t$1m7$1@build.eclipse.org...
>>> I believe there is still some problem with the list of item I'm
>>> passing to the table viewer ...
>>> the same list that was giving me problem before (that works removing
>>> the virtual attribute) now is giving me problem when a new input is
>>> set in the viewer ...
>>> just to be clear ...
>>> the table viewer has got the list of item that was generating the
>>> error before:
>>> now when I select a new input I get this error (and again ... I can
>>> see that he is trying to disassociate a null element)
>>> where should I look ... for sure the items in the list ARE NOT NULL ...
>>> can it be some problem due to object hash????
>>> thanks
>>> org.eclipse.core.runtime.AssertionFailedException: null argument:
>>> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
>>> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
>>> at
>>> org.eclipse.jface.viewers.StructuredViewer.disassociate(Stru cturedViewer.java:618)
>>> at
>>> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres hAll(AbstractTableViewer.java:711)
>>> at
>>> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:633)
>>> at
>>> org.eclipse.jface.viewers.AbstractTableViewer.internalRefres h(AbstractTableViewer.java:620)
>>> at
>>> org.eclipse.jface.viewers.AbstractTableViewer$2.run(Abstract TableViewer.java:576)
>>> at
>>> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1368)
>>> at
>>> org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1330)
>>> at
>>> org.eclipse.jface.viewers.AbstractTableViewer.inputChanged(A bstractTableViewer.java:574)
>>> at
>>> org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:251)
>>> at
>>> org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1606)
>>> news:gemlgk$rs5$1@build.eclipse.org...
>>>> Maybe because there is/was a bug in 3.3.2? We fixed some
>>>> Virtual-Problems in 3.4.
>>>> Tom
>>>> Kar schrieb:
>>>>> Hi Tom
>>>>> error removed ... but still don't understand why
>>>>> I was using the type SWT.VIRTUAL creating the table ...
>>>>> TableViewer viewer = new TableViewer(parent, SWT.H_SCROLL |
>>>>> SWT.V_SCROLL
>>>>> | SWT.BORDER
>>>>> | SWT.FULL_SELECTION | SWT.MULTI);
>>>>> Removing virtual I don't see the error anymore ...
>>>>> why?
>>>>> news:gemjn0$f4l$1@build.eclipse.org...
>>>>>> What's the content around line CustomHashtable 264? Looks like you
>>>>>> are
>>>>>> inserting an NULL value and TableViewer can't deal with
>>>>>> null-references.
>>>>>> Tom
>>>>>> Kar schrieb:
>>>>>>> Hi all
>>>>>>> view) .
>>>>>>> the table view is populated with a list of objects. .
>>>>>>> what am I doing wrong?
>>>>>>> java.lang.NullPointerException
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>>>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>>>>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
>>>>>>> Source)
>>>>>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>>>>>> at
>>>>>> B e s t S o l u t i o n . at
>>>>>> Tom Schindl JFace-Committer
Re: tableviewer error on events ... eclipse 3.3.2 [message #332640 is a reply to message #332638] |
Mon, 03 November 2008 08:02  |
I have been following with the debug the creation of the view when I add the
input that gives me problem ...
Table viewer Abstract table viewer ... interalrefresh all ...
it just gets 4 items ... and for what I'm seeing except the already present
item in the view it is just creating up to the number of item I need
for (int i = min; i < children.length; ++i) {
createItem(children[i], i);
[ children.length ==4 ]
but who knows why ... when I do set the input again ... the doGetItems gives
me back the array with 25 items I sent before ...
news:gemr36$bdl$1@build.eclipse.org...
> no :-(
>> and not change.
>> Tom
>>> thanks
>>>> error before:
>>>> thanks
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Tom
>>>>> Kar schrieb:
>>>>>> Hi Tom
>>>>>> SWT.V_SCROLL
>>>>>> | SWT.BORDER
>>>>>> why?
>>>>>>> are
>>>>>>> null-references.
>>>>>>> Tom
>>>>>>> Kar schrieb:
>>>>>>>> Hi all
>>>>>>>> view) .
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Method)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Method)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
FUDForum. Page generated in 0.04576 seconds
