Home » Eclipse Projects » Eclipse Platform » How to execute an external program from a plugin
How to execute an external program from a plugin [message #332602] Thu, 30 October 2008 11:47 Go to next message
Originally posted by: mam05eux.studserv.uni-leipzig.de
i´ve built a plugin that calls an external c#-Program to import some
things using the .Net-Framework.
Ok, during the development of the plugin everything works fine (The
program "*.exe" lies in a subfolder named "temp" of the project) because
the plugin is loaded from the project, so it has a real filepath which I
get using the getInstallUri-Method.
Now my problem: When I export the plugin as a jar the exe cannot be
launched because the file lies within the jar.
So is there any possibility to execute the program at this location or
if not, how can i export a plugin as a directory so that eclipse is able
to load the plugin like a jar (I just tried to extract the contents of
the exportet jar and add the directory to the eclipse-plugin folder but
as I´ve expected eclipse didn´t load the plugin).
Thanks for the moment!
Re: How to execute an external program from a plugin [message #332604 is a reply to message #332602] Thu, 30 October 2008 13:14 Go to previous messageGo to next message
FileLocator#find(Bundle bundle, IPath path, Map override)
will return a URL for the entry in your bundle.
Then
FileLocator.toFileURL(URL)
will extract the entry to a cache (normally under the
configuration/org.eclipse.osgi directory) and return the URL to the
location on disk.
If you have an Activator for your bundle, you can get your Bundle object
from the BundleContext, otherwise you could use Platform#getBundle
The FileLocator class is in org.eclipse.equinox.common
-Andrew
Stanley Hillner wrote:
> Hello,
Re: How to execute an external program from a plugin [message #332609 is a reply to message #332604] Fri, 31 October 2008 02:19 Go to previous messageGo to next message
> Then
> location on disk.
Andrew, how long is this cache alive for? Will the file be deleted
automagically or...?
>> able to load the plugin like a jar (I just tried to extract the
>> contents of the exportet jar and add the directory to the
>> eclipse-plugin folder but as I´ve expected eclipse didn´t load the
>> plugin).
There should be a way to export as a directory through the regular
export wizard, I've done it before (and continue to do it on occasions
when I need to update my application). I'm not sure how to do it through
pdebuild though.
Rem
Re: How to execute an external program from a plugin [message #332613 is a reply to message #332609] Fri, 31 October 2008 10:55 Go to previous messageGo to next message
Each bundle gets its own cache space. It should be cleaned up if the
bundle gets uninstalled, but otherwise I think it stays unless someone
runs with -clean.
In a headless build the shape of the built plugin depends on what the
containing feature says for the "unpack" attribute on the plug-in entry.
If not specified, the default is "true", which results in a folder.
If you are running productBuild.xml with a .product, and the container
feature is generated for you, then we guess, which is based on whether
or not the Bundle-Classpath has a '.' on it.
-Andrew
>> Then
>> location on disk.
> >> plugin).
> pdebuild though.
> Rem
Re: How to execute an external program from a plugin [message #332704 is a reply to message #332613] Thu, 06 November 2008 04:04 Go to previous message
Thanks for your replies.
I´m sorry that I wasn´t able to answer earlier but there was too much to
do at other projects.
So this tip worked fine, thanks a lot!
Stanley
> runs with -clean.
> -Andrew
>>> Then
>>> location on disk.
>> >> plugin).
>> through pdebuild though.
>> Rem
Previous Topic:Synchronize view not showing files in conflict mode after update
Next Topic:Multiline TreeViewer
Current Time: Mon Jul 21 21:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.22787 seconds
