Home » Eclipse Projects » Eclipse Platform » Installation error: An error occurred during provisioning
Installation error: An error occurred during provisioning [message #332580] Wed, 29 October 2008 15:07 Go to next message
What does this mean, and how do I recover from it?
An error occurred during provisioning.
Error with signed content.
Either the manifest file or the signature file has been tampered in
this jar:
C:\Java\ganymede\plugins\org.eclipse.hyades.analysis.engine_ 4.4.0.v200804221626
Re: Installation error: An error occurred during provisioning [message #332581 is a reply to message #332580] Wed, 29 October 2008 15:12 Go to previous messageGo to next message
> this jar:
I deleted the "tampered with" plugin, but now the install fails
saying it can't find the directory. I thought the installer
was smart enough to figure out what it needed and download it.
Can someone tell me how to recover from this and continue with
the install?
Re: Installation error: An error occurred during provisioning [message #332595 is a reply to message #332581] Thu, 30 October 2008 09:39 Go to previous messageGo to next message
>> this jar:
It is not a good idea to go deleting things from behind its back; p2
(the new "provisioning" [that is, install and update] mechanism now
manages those much more tightly than before). Other than restoring the
deleted plugin, I'm not sure what can be done. You might try also
removing the corresponding Haydes feature (if there is one) and
re-starting Eclipse with the -clean command-line argument. I'm not
promising that will help, but it might.
Eric
Re: Installation error: An error occurred during provisioning [message #332603 is a reply to message #332595] Thu, 30 October 2008 12:06 Go to previous message
>>> this jar:
Thanks. It was easier just to reinstall Eclipse from scratch :-)
Previous Topic:Loading resources with getResource
Next Topic:projects located in the workspace folder must be direct sub folders of the works
Current Time: Sat Jul 19 03:24:38 EDT 2025
Powered by FUDForum. Page generated in 0.05524 seconds
