| Empty Error in Europa [message #33728] |
Thu, 05 July 2007 09:35  |
I have just installed Europa together with all the prerequisites for PDT.
The problem I'm having occurs when trying to create a new PHP file in a
project. I enter the filename and upon clicking Finish I get an empty
error popup and the file isn't created, that is, the "New PHP File" wizard
is left open.
Here's the screenshot: http://img489.imageshack.us/img489/4553/errorll3.png
What could be the problem?
| Re: Empty Error in Europa [message #34615 is a reply to message #34021] |
Sun, 08 July 2007 08:14  |
I've submitted a bug for this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195758
Thanks for your report.
Guy Gurfinkel,
Team Leader, Development Tools
Zend.
"Piotr Szczepanik" <piter75@gmail.com> wrote in message
news:f6j96c$9ah$1@build.eclipse.org...
> ReeD wrote:
>> Did you find a workaround to this problem? It sucks having to create
>> files manually outside of Eclipse.
> Sorry.
> I haven't read your message carefully enough :(
> I don't click finish there, I click "Next" instead.
> Then if you choose the standard PHP template for file everything is OK.
> For me it gives similar error when I choose to create an empty file.
> So as a "workaround" I create a file based on standard template which is
> "<?php\n\n?>".
> Best regards,
> Piotr Szczepanik
FUDForum. Page generated in 0.03615 seconds
