| Plugin properties from external plugins [message #332538] | Mon, 27 October 2008 12:12  |  |
| Eclipse User  |  |  |  |  | Hi there,
 is it possible, to use plugin properties from a other plugin?
 For example: If you use the function "Externalize Strings", a
 plugin.properties file will be created in the root folder of the plugin.
 Is there a possibility to move this file to a other plugin?
 bin.includes = plugin.xml,\
 META-INF/,\
 icons/,\
 plugin.properties -> maybe plugin.xyz\plugin.properties
 regards,
 Markus
| Re: Plugin properties from external plugins [message #332539 is a reply to message #332538] | Mon, 27 October 2008 12:38  |  |
| Eclipse User  |  |  |  |  | Markus,
 I don't think so. This tends to lead to some duplication. :-(
 Markus Schindler wrote:
 > Hi there,
 > plugin. Is there a possibility to move this file to a other plugin?
 >               META-INF/,\
 >               icons/,\
 > regards,
 > Markus
FUDForum. Page generated in 0.03064 seconds
