| Plugin properties from external plugins [message #332538] |
Mon, 27 October 2008 12:12  |
Hi there,
is it possible, to use plugin properties from a other plugin?
For example: If you use the function "Externalize Strings", a
plugin.properties file will be created in the root folder of the plugin.
Is there a possibility to move this file to a other plugin?
bin.includes = plugin.xml,\
META-INF/,\
icons/,\
plugin.properties -> maybe plugin.xyz\plugin.properties
regards,
Markus
| Re: Plugin properties from external plugins [message #332539 is a reply to message #332538] |
Mon, 27 October 2008 12:38  |
Markus,
I don't think so. This tends to lead to some duplication. :-(
Markus Schindler wrote:
> Hi there,
> plugin. Is there a possibility to move this file to a other plugin?
> META-INF/,\
> icons/,\
> regards,
> Markus
FUDForum. Page generated in 0.04441 seconds
