Home » Language IDEs » PHP Development Tools (PDT) » Empty Error in Europa
Empty Error in Europa [message #33728] Thu, 05 July 2007 09:35 Go to next message
I have just installed Europa together with all the prerequisites for PDT.
The problem I'm having occurs when trying to create a new PHP file in a
project. I enter the filename and upon clicking Finish I get an empty
error popup and the file isn't created, that is, the "New PHP File" wizard
is left open.
Here's the screenshot: http://img489.imageshack.us/img489/4553/errorll3.png
What could be the problem?
Re: Empty Error in Europa [message #33763 is a reply to message #33728] Thu, 05 July 2007 10:52 Go to previous messageGo to next message
ReeD wrote:
> in a project. I enter the filename and upon clicking Finish I get an
> empty error popup and the file isn't created, that is, the "New PHP
> File" wizard is left open.
This started happening to me also after upgrade to 3.3.
I think this needs a bugzilla entry ;)
Piotr Szczepanik
Re: Empty Error in Europa [message #33864 is a reply to message #33763] Thu, 05 July 2007 11:31 Go to previous messageGo to next message
Did you find a workaround to this problem? It sucks having to create files
manually outside of Eclipse.
Re: Empty Error in Europa [message #34021 is a reply to message #33864] Thu, 05 July 2007 13:19 Go to previous messageGo to next message
> files manually outside of Eclipse.
Sorry.
I haven't read your message carefully enough :(
I don't click finish there, I click "Next" instead.
Then if you choose the standard PHP template for file everything is OK.
For me it gives similar error when I choose to create an empty file.
So as a "workaround" I create a file based on standard template which is
"<?php\n\n?>".
Piotr Szczepanik
Re: Empty Error in Europa [message #34615 is a reply to message #34021] Sun, 08 July 2007 08:14 Go to previous message
I've submitted a bug for this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195758
Thanks for your report.
Guy Gurfinkel,
Team Leader, Development Tools
Zend.
"Piotr Szczepanik" <piter75@gmail.com> wrote in message
news:f6j96c$9ah$1@build.eclipse.org...
> Sorry.
> "<?php\n\n?>".
> Best regards,
> Piotr Szczepanik
Previous Topic:Creating php model with europa is takes 4ever
Next Topic:Using PDT with RSE results in NullPointerException
Current Time: Mon Nov 10 07:19:21 EST 2025
Powered by FUDForum. Page generated in 0.04531 seconds
