Home » Eclipse Projects » Eclipse Platform » myEditorPart#saveState(IMemento) not being called
myEditorPart#saveState(IMemento) not being called [message #332454] Tue, 21 October 2008 16:12 Go to next message
I wanted to create a custom editor (where I supply both the EditorPart
and IEditorInput implementation) where Eclipse remembers what editors
are open and reopens them when the platform closes and reopens.
Searching the web found
http://dev.eclipse.org/newslists/news.eclpse.platform/msg631 07.html
which recommends having my editor implement the IPersistableEditor
interface.
After implementing this interface in my EditorPart (and making sure that
I called configurer.setSaveAndRestore(true)), the IPersistable#saveState
and IPersistableEditor#restoreState methods were never called.
(Verified using the debugger.)
I also found:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg08987.html
but it appears to apply to the 2.2 api only and attempting to use it
also failed in new and interesting ways. :-)
What am I missing/What should I try next?
Dave Orme
Re: myEditorPart#saveState(IMemento) not being called [message #332477 is a reply to message #332454] Tue, 21 October 2008 19:20 Go to previous messageGo to next message
Those are the 2 main things you need.
Your editor must implement org.eclipse.ui.IPersistableEditor. your
IEditorInput must return an org.eclipse.ui.IPersistableElement. its
factory ID must match your org.eclipse.ui.IElementFactory, and you need
to use the org.eclipse.ui.elementFactories extension to link the ID to
the factory.
If you've done all the steps and it's still not working, maybe there's a
bug in the system (although this works for FileEditorInput, amongst
others). Maybe a bug against Eclipse Platform UI and a small test plugin.
PW
Paul Webster
Re: myEditorPart#saveState(IMemento) not being called [message #332487 is a reply to message #332477] Wed, 22 October 2008 11:06 Go to previous message
Thanks for your help, Paul.
I've tried this, and put System.out.printlns in the:
EditorInput#saveState
EditorInputFactory#createElement
Editor#saveState
Editor#restoreState
methods.
For the purposes of the example, my IEditorInput contains a String and
my Editor contains a Text widget. The "text" property of the Editor's
Text widget is data-bound to a property of the EditorInput. The editor
itself has no state that it persists--all of its state is persisted in
the IMemento in the IEditorInput.
Running the example, creating two editors, and typing "Editor 1" into
one and "Editor 2" into the second yields the following output when
shutting down and restarting the application:
Shutdown:>>>>>>>>>>>>>>>>>>>
EditorInput.saveState>>>> Editor 1
EditorInput.saveState>>>> Editor 2
Startup:>>>>>>>>>>>>>>>>>>>>
CreateElement>>>> Editor 1
and no editors are actually restored.
Notice also that Editor.saveState is never called.
I feel like there must be a "Doh!" somewhere, but am clueless as to
where...
Source code to my example is available at:
http://www.coconut-palm-software.com/~djo/org.eclipse.exampl es.saveditorstate.zip
Thanks in advance,
Dave Orme
> the factory.
> PW
Previous Topic:Handle ESC press to a whole shell as ENTER is handled with setDefaultButton
Next Topic:CVS: reverting to previous revision
Current Time: Thu Jul 17 22:08:17 EDT 2025
Powered by FUDForum. Page generated in 0.06528 seconds
