Home » Eclipse Projects » Eclipse Platform » Handle ESC press to a whole shell as ENTER is handled with setDefaultButton
Handle ESC press to a whole shell as ENTER is handled with setDefaultButton [message #332379] Mon, 20 October 2008 14:10 Go to next message
As there is a setDefaultButton in Shell/Decoration to handle ENTER on a
shell, there is a way to handle a ESC press to the whole shell too? I could
not find it anywhere.
Marcelo
Re: Handle ESC press to a whole shell as ENTER is handled with setDefaultButton [message #332463 is a reply to message #332379] Tue, 21 October 2008 18:22 Go to previous messageGo to next message
No hints about this issue?
Thanks again! :-)
"Marcelo Alcantara" <marcelo.alcantara@cshg.com.br> escreveu na mensagem
news:gdihj5$2de$1@build.eclipse.org...
> could not find it anywhere.
> Marcelo
Re: Handle ESC press to a whole shell as ENTER is handled with setDefaultButton [message #332475 is a reply to message #332463] Tue, 21 October 2008 19:11 Go to previous messageGo to next message
AFAIK ESC can generate SWT.Traverse events. Added at the Shell level, a
TraverseListener could close the shell.
Is this what you are looking for?
PW
Paul Webster
Re: Handle ESC press to a whole shell as ENTER is handled with setDefaultButton [message #332483 is a reply to message #332475] Wed, 22 October 2008 08:11 Go to previous messageGo to next message
Hi Paul,
I solved the issue adding a filter to the display:
display.addFilter(SWT.KeyDown, new Listener()
public void handleEvent(Event e)
switch (e.keyCode)
case SWT.ESC:
Display.getCurrent().getActiveShell().close();
break;
Thanks for your help anyway.
Regads,
Marcelo
"Paul Webster" <pwebster@ca.ibm.com> escreveu na mensagem
news:gdlo16$kfp$2@build.eclipse.org...
> PW
> Paul Webster
Re: Handle ESC press to a whole shell as ENTER is handled with setDefaultButton [message #332484 is a reply to message #332483] Wed, 22 October 2008 08:48 Go to previous message
On 10/22/2008 8:11 AM, Marcelo Alcantara wrote:
> Hi Paul,
This is definitely a hack and I would strongly recommend you look at the
TraverseListener solution that Paul offered. Display filters apply to
all windows and widgets and thus this kind of listener is dangerous - if
you don't remove it it will probably result in undesired behavior after
your dialog is closed.
> switch (e.keyCode)
> case SWT.ESC:
> break;
> Regads,
> Marcelo
> "Paul Webster"<pwebster@ca.ibm.com> escreveu na mensagem
>> PW
>> Paul Webster
Previous Topic:Updates and restoreState
Next Topic:myEditorPart#saveState(IMemento) not being called
Current Time: Mon Oct 20 23:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.05791 seconds
