Home » Modeling » TMF (Xtext) » TMF and GMF
| TMF and GMF [message #33699] |
Tue, 24 March 2009 12:57  |
Does xtext support generating corresponding GMF plugins? Since the EMF
ecore file can be used to create a GMF plugin, the question is, would the
outcome TMF and GMF plugins be synchronised at runtime? For example, when
we edit the GMF diagram, does it automatically update the TMF text file
and vice versa? Is the same applied to an EMF editor?
| Re: TMF and GMF [message #33733 is a reply to message #33699] |
Tue, 24 March 2009 14:03   |
Hi Auerliano,
yes, you can edit a model that was created with an Xtext editor with a
GMF Editor. It is stored in plain text.
However, Xtext supports some features, that other editors are not aware
of (namely classpath URIs). Furthermore some issues with serialization
are still pending. But if you try to avoid problematic constructs in
your concrete textual syntax, then you can use generic (EMF), graphical
(GMF) and textual (Xtext) editors in parallel.
Sebastian
Auerliano schrieb:
> the outcome TMF and GMF plugins be synchronised at runtime? For example,
> when we edit the GMF diagram, does it automatically update the TMF text
> file and vice versa? Is the same applied to an EMF editor?
| Re: TMF and GMF [message #33767 is a reply to message #33733] |
Tue, 24 March 2009 15:12   |
Sebastian Zarnekow wrote:
Hi Sebastian,
When you say 'it is stored in plain text', do you mean the xml file shared
between EMF, GMF and TMF editors? When I create a *.dmodel file for the
domainmodel example, I don't see any xml file being created as well, but
EMF and GMF do share the xml file. Am I missing something?
> Hi Auerliano,
> Sebastian
> Auerliano schrieb:
| Re: TMF and GMF [message #33801 is a reply to message #33767] |
Wed, 25 March 2009 03:14  |
Hi Auerliano,
no I didn't mean an XML file, but the dmodel-file itself.
It should be possible to open the dmodel-file with the generic ecore
editor, modify it and press save.
Sebastian
> Hi Sebastian,
> shared between EMF, GMF and TMF editors? When I create a *.dmodel file
> for the domainmodel example, I don't see any xml file being created as
> well, but EMF and GMF do share the xml file. Am I missing something?
>> Hi Auerliano,
>> aware of (namely classpath URIs). Furthermore some issues with
>> serialization are still pending. But if you try to avoid problematic
>> constructs in your concrete textual syntax, then you can use generic
>> (EMF), graphical (GMF) and textual (Xtext) editors in parallel.
>> Regards,
>> Sebastian
>> Auerliano schrieb:
>>> Hi,
>>> EMF ecore file can be used to create a GMF plugin, the question is,
>>> would the outcome TMF and GMF plugins be synchronised at runtime? For
>>> example, when we edit the GMF diagram, does it automatically update
>>> the TMF text file and vice versa? Is the same applied to an EMF editor?
Current Time: Fri Nov 07 13:20:01 EST 2025
Powered by FUDForum. Page generated in 0.03674 seconds
