Re: JFace Table Viewer Editor [message #332361] |
Mon, 20 October 2008 09:38  |
On 10/18/2008 6:30 PM, Jared Warren wrote:
> First off - I'm not sure if this is the right place for JFace questions.
> If it's not, please kindly tell me to shove off (and, if you can,
> point me in the right direction.)
JFace is a layer above SWT, so JFace questions are best posted to the
eclipse.platform newsgroup. I've copied that group to this thread.
More below...
> I have two different applications using the JFace TableViewer. In each
> case, after I've added my CellModifiers and I start trying to edit the
> contents of the cells, I have to click in the first column of a given
> row before I can click into other columns of the same row to edit. Is
> there a common "oopsie" that can cause this problem?
You are probably better off using the newer viewer-editing API
(org.eclipse.jface.viewers.EditingSupport). There are several examples
on the JFace snippets page,
http://wiki.eclipse.org/index.php/JFaceSnippets (for example,
http://wiki.eclipse.org/index.php/JFaceSnippets#Snippet019Ta bleViewerAddRemoveColumnsWithEditingNewAPI)
Hope this helps,
Eric
Re: JFace Table Viewer Editor [message #332375 is a reply to message #332361] |
Mon, 20 October 2008 12:29  |
Eric Rizzo wrote:
Both of you were correct....
I wasn't including SWT.FULL_SELECTION in the style (which fixed the bug),
and the new Editing framework does look like it would be a better option -
I'll be switching to it as I continue work.
jared
> More below...
> Hope this helps,
> Eric
FUDForum. Page generated in 0.24888 seconds
