Home » Eclipse Projects » Eclipse Platform » Marker Annotations disapperaring in vertical toolbar
Marker Annotations disapperaring in vertical toolbar [message #332341] Fri, 17 October 2008 11:19 Go to next message
Hi All,
I'm noticing a problem with markers in our editor. Lets assume I
have 10 variables, each one of them has an annotation along the
vertical toolbar indicating that there is a problem with the variable (
variable not used for example).
Anyway, if I select some of those variables and change their type(via a bulk
copy and paste for example) I get different types of annotations (again,
this is supposed to happen in our editor, so all OK so far).
Now, lets say I change the data types of the variables back to their
original type, what I expect to see is the original annotations being
displayed in the vertical
toolbar but this is not the case for ALL variables.
I am noticing that some of the variables do show their correct annotation
but a few others don't show anything in the toolbar!
The underlying code for gathering and updating the error markers is correct
so I cannot understand why the GUI is not showing the correct annotations.
I'm sorry if I am not clear but I am new enough to this area and it's some
bug fixing that I'm doing :-)
Can anyone give me some pointers as to where to look for the solution? Are
there some obvious thing I need to check first?
Thanks in advance!
g.
Re: Marker Annotations disapperaring in vertical toolbar [message #332343 is a reply to message #332341] Mon, 20 October 2008 05:11 Go to previous messageGo to next message
Anyone???
"gdollard" <glenn.dollard@gmail.com> wrote in message
news:gdhhkp$t52$2@build.eclipse.org...
> Hi All,
> bulk copy and paste for example) I get different types of annotations
> (again, this is supposed to happen in our editor, so all OK so far).
> correct so I cannot understand why the GUI is not showing the correct
> annotations.
> Thanks in advance!
> g.
Re: Marker Annotations disapperaring in vertical toolbar [message #332497 is a reply to message #332343] Thu, 23 October 2008 09:38 Go to previous message
Originally posted by: swanbrook66.gmail.com
gdollard wrote:
> Anyone???
>> Hi All,
>> annotations.
>> Thanks in advance!
>> g.
Doing something very similar here and also running into the same
problem. Would be interested in hearing how you get on and if you make
any progress
Thanks.
Previous Topic:Problem integrating equinox transforms (xslt)
Next Topic:Re: Error launching the preference page
Current Time: Thu Nov 27 16:46:36 EST 2025
Powered by FUDForum. Page generated in 0.04146 seconds
