| Marker Annotations disapperaring in vertical toolbar [message #332341] |
Fri, 17 October 2008 11:19  |
Hi All,
I'm noticing a problem with markers in our editor. Lets assume I
have 10 variables, each one of them has an annotation along the
vertical toolbar indicating that there is a problem with the variable (
variable not used for example).
Anyway, if I select some of those variables and change their type(via a bulk
copy and paste for example) I get different types of annotations (again,
this is supposed to happen in our editor, so all OK so far).
Now, lets say I change the data types of the variables back to their
original type, what I expect to see is the original annotations being
displayed in the vertical
toolbar but this is not the case for ALL variables.
I am noticing that some of the variables do show their correct annotation
but a few others don't show anything in the toolbar!
The underlying code for gathering and updating the error markers is correct
so I cannot understand why the GUI is not showing the correct annotations.
I'm sorry if I am not clear but I am new enough to this area and it's some
bug fixing that I'm doing :-)
Can anyone give me some pointers as to where to look for the solution? Are
there some obvious thing I need to check first?
Thanks in advance!
g.
| Re: Marker Annotations disapperaring in vertical toolbar [message #332497 is a reply to message #332343] |
Thu, 23 October 2008 09:38  |
Originally posted by: swanbrook66.gmail.com
gdollard wrote:
> Anyone???
> "gdollard" <glenn.dollard@gmail.com> wrote in message
> news:gdhhkp$t52$2@build.eclipse.org...
>> Hi All,
>> bulk copy and paste for example) I get different types of annotations
>> (again, this is supposed to happen in our editor, so all OK so far).
>> correct so I cannot understand why the GUI is not showing the correct
>> annotations.
>> Thanks in advance!
>> g.
Doing something very similar here and also running into the same
problem. Would be interested in hearing how you get on and if you make
any progress
Thanks.
FUDForum. Page generated in 0.07879 seconds
