Home » Eclipse Projects » Eclipse Platform » Incorrect shortcut behaviour: show view: declaration
Incorrect shortcut behaviour: show view: declaration [message #332331] Sun, 19 October 2008 21:48 Go to next message
Hi All,
Ganymede Version: 3.4.0
Build id: I20080617-2000
I have two short-cuts showing for "Show View (View: Declaration)" as shown
here:
http://lh3.ggpht.com/robertmarkbram/SPvgTP_j0nI/AAAAAAAAKZM/ xuB5DeWZThE/s912/eclipseShowViewDeclaration.PNG
Neither of these shortcuts show any conflicts..
The Alt+Shift+Q,D short cut will take me to either the Java Declaration
view or the Javascript Declaration view depending on whether I am in a
Java editor or Javascript editor - but still works (taking me to whichever
declaration was last opened) when I press it from *any other* view as well!
The Alt+D short cut only takes me to the Javascript declaration view
*only* if I am in a Javascript editor..
What is different between these? Neither seems to be obeying the on-screen
contract..
I want Alt+D to do this - but simply unbinding the Alt+D shortcut and
changing Alt+Shift+Q,D to Alt+D doesn't work - instead I end up with the
old Alt+D behavior.
Any assistance would be appreciated!
Rob
Re: Incorrect shortcut behaviour: show view: declaration [message #332471 is a reply to message #332331] Tue, 21 October 2008 19:04 Go to previous message
> on-screen contract..
> old Alt+D behavior.
It has to do with the "When". It says Javascript view but really it is
a context that is activated by some of the JavaScript plugin code
(editor maybe, or view, or perspective activation).
ALT+SHIFT+Q D is bound in the "In Windows" context
PW
Paul Webster
Previous Topic:No Handler error
Next Topic:Project specific formatting - where are the settings stored?
Current Time: Fri Nov 14 19:49:56 EST 2025
Powered by FUDForum. Page generated in 0.24349 seconds
