Home » Eclipse Projects » Eclipse Platform » No Handler error
No Handler error [message #332325] Sun, 19 October 2008 04:25 Go to next message
Hi ,
I am working on a cheat sheet , in one of the steps in cheatsheet i want the
user to checkout the code from CVS/Subversion. I had added the command
"addLocation" of the CVS. When I execute the command it fails saying " No
Handler Error" , but when I change from my existing perspective to CVS
Perspective , then execute it it works well .But in real time that will not
be the scenario, I want the user to make use of the cheatsheet in any
prespective he is in . I did see an article in Dzone but could'nt understand
whats said there .
Can anyone help on how to aovid this issue ?
Thanks.
Kamesh
Re: No Handler error [message #332470 is a reply to message #332325] Tue, 21 October 2008 18:56 Go to previous message
It sounds like that action is in an actionSet, and is not active in your
perspective. Is that the case?
PW
Paul Webster
Previous Topic:How to use / customize eclipse logger
Next Topic:Incorrect shortcut behaviour: show view: declaration
Current Time: Thu Jul 17 10:26:26 EDT 2025
Powered by FUDForum. Page generated in 0.27514 seconds
