Home » Eclipse Projects » Eclipse Platform » Is Ant built-in/included in Eclipse v3.3.2?
Is Ant built-in/included in Eclipse v3.3.2? [message #332283] Thu, 16 October 2008 14:48 Go to next message
Originally posted by: markmccloud200.email.com
Is Ant built-in/included in Eclipse v3.3.2 or do I have to install it seperately?
If I have to install it in addition: How do I execute build.xml as an ANT task?
In other words: How do I use Ant from within Eclipse (not from the command
line)?
Mark
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332284 is a reply to message #332283] Thu, 16 October 2008 20:19 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
It's included.
1. Open your Ant script in the Ant editor within Eclipse (you might need
to associate build.xml or *.xml with that editor first, using Window >
Preferences > File Associations).
2. Use ALT-SHIFT-X,Q to run the ant script; use ALT-SHIFT-D,Q to debug
the ant script.
OR
1. Drag the Ant script from Package Explorer into the Ant view.
2. Double-click the target within the script you want to run (or
right-click and you can select Debug As > Ant Build).
> line)?
> Mark
Nick Boldt :: http://wiki.eclipse.org/index.php/User:Nickb
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332288 is a reply to message #332283] Fri, 17 October 2008 04:33 Go to previous messageGo to next message
On Thu, 16 Oct 2008 18:48:43 +0000 (UTC), markmccloud200@email.com
There is an Ant plug-in but I'm not sure if it's installed with all
packages. I have never installed an Ant seperately.
>line)?
Open the Ant View from the "Window/Show View" menu and drag your ant
script into this view. If you use "build.xml" as file name this will
work directly, otherwise you should add your filename pattern to the
Ant preferences.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332303 is a reply to message #332283] Fri, 17 October 2008 11:31 Go to previous messageGo to next message
Eclipse 3.3.2 includes Ant 1.7.0.
Look in the plugins directory and you should see a folder
org.apache.ant_1.7.0.v200706080842
which is ant packaged up as an OSGi bundle.
You can run ant files by creating launch configurations under Run ->
External Tools -> External Tools Configurations...
The other methods that have been mentioned are really just shortcuts for
this.
> line)?
> Mark
Re: Is Ant built-in/included in Eclipse v3.3.2? [message #332321 is a reply to message #332283] Sat, 18 October 2008 17:33 Go to previous message
Hey Mark
Eclipse 3.3.2 comes with Ant 1.7.0 included.
The simplest way to invoke an Ant build for your build.xml you can right
click to get the context menu>Run As>Ant Build
This will do the build starting with the default target.
If you need to get more fancy, use the context menu>Run As>Ant Build... to
configure the target, extra parameters, classpath, etc
To dig into more details, please check out:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.user/concepts/concepts-antsupport.htm
HTH
Darins
http://www.runnerwhocodes.blogspot.com/
"Mark McCloud" <markmccloud200@email.com> wrote in message
news:gd82aa$nai$1@build.eclipse.org...
> seperately?
> task?
> line)?
> Mark
Previous Topic:How do I detect which (latest) version of WTP is currently installed?
Next Topic:Contribute Run External Program Actions via Plugin
Current Time: Fri Jul 18 07:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.03906 seconds
