Home » Eclipse Projects » Eclipse Platform » How to remote debug?
| How to remote debug? [message #332280] |
Thu, 16 October 2008 12:04  |
Originally posted by: vblant.shaw.ca
Hello. I've been trying to use Eclipse's remote debugging capabilities,
but I just can't get it to work. This probably means that I have a lot of
misconceptions about how it works, so I hope someone here can clear them
up for me.
Here is what I am trying to set up. I have a junit test that fails only
when it is executed by my ANT target (it works if I run it from eclipse
directly). So, I though that I will use Eclipse to remote debug the test
when it is executed by ANT. In order to do this, I performed the following
steps, which I thought would get me there:
1) Run ANT with debugging parameters, like this:
"/usr/lib/jvm/java-1.5.0-sun/jre/bin/java" -Xdebug
-Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=104 4 -classpath
" /usr/share/ant/lib/ant-launcher.jar:/usr/share/java/xmlParse rAPIs.jar:/usr/share/java/xercesImpl.jar "
-Dant.home="/usr/share/ant" -Dant.library.dir="/usr/share/ant/lib"
org.apache.tools.ant.launch.Launcher -cp "" "integration-tests-agriInvest"
2) I made a "Remote Java Application" launcher in Eclipse and set it up to
connect to localhost:1044
3) On the 'Source' tab I made sure to add the project where the source
code for my junit is.
The result of this setup is that when I run Step 1, ANT correctly
tells me: "Listening for transport dt_socket at address: 1044" and waits
until I go to Eclipse and launch my remote configuration. As the test
runs, I can see the remote threads in Eclipse, so everything looks good.
However, I can't get Eclipse to stop on my breakpoint! What am I missing?
Please help. Thanks.
Val
| Re: How to remote debug? [message #332293 is a reply to message #332280] |
Fri, 17 October 2008 09:12   |
> up for me.
Sounds like you did pretty much everything correctly. The only thing I
can think of to ask is, did you select the appropriate Project when
creating the debug launch config, not on the Source tab but on the
Connect tab? If you do that, you should not usually have to set any
additional stuff on the Source tab.
Hope this helps,
Eric
| Re: How to remote debug? [message #332423 is a reply to message #332308] |
Tue, 21 October 2008 09:19   |
>> Hope this helps,
>> Eric
> My application actually consists of many different Eclipse projects. On
> the Connect tab I selected the project that contains the junit test I
> wanted to debug. Is this correct?
Generally, yes. I'm trying to think of what kind of setup would cause it
to not hit breakpoints, and I'm coming up mostly blank.
Does the JUnit project depend on the other projects directly, or on JARs
that are produced from those projects?
Maybe if you describe your project setup in more detail, we might spot
something that is out of the ordinary...
Eric
| Re: How to remote debug? [message #332451 is a reply to message #332435] |
Tue, 21 October 2008 15:41  |
> Here is how my projects are setup:
> OPS - Container project for all kinds of library jars that all other
> projects include in their build path
> OPSCommon
> OPSShared (depends on OPSCommon)
> OPSBusiness (depends on OPSCommon, OPSShared) - this is where the
> JUnit test is
> OPSWeb (depends on OPSCommon, OPSShared, OPSBusiness)
In what project(s) have you set the breakpoint(s) that are not hit when
you debug the JUnit test?
One other idea I had: try deleting the launch configuration for your
test, then right-click on the test class (or package or project that
contains it) and choose Debug As > JUnit Test. That will force it to
re-generate a new launch configuration that should (hopefully) be correct.
Eric
Current Time: Tue Nov 04 11:46:29 EST 2025
Powered by FUDForum. Page generated in 0.05542 seconds
