Home » Eclipse Projects » Eclipse Platform » view action delegate with sub menu ...
view action delegate with sub menu ... [message #332277] Thu, 16 October 2008 08:22 Go to next message
Hi all,
I need to implement a view action that will display, as a submenu, a list of
actions when selected ... the action comes from extension point (view action
delegate)
VIEW CONTEXT MENU
________________
- Action 1
- Action 2
- List Action
- sub action a
- sub action b
- sub action c
- sub action d
- Action 3
I'll try to describe what I need to do ...
I have a list of names that I know at runtime ...
When I select an item in my view I would like to see in the context menu my
"List Action" action with a submenu that will list the actions (each one
named with the name I read when the application when it starts ...)
I have found a way to do this via a normal action (jface.action) where I can
override the setMenuCreator (with IMenuCreator) ...
But what shall I do here ...
This action is contributed to my view from a fragment so I cannot directly
add the action to the context menu and I cannot create in the
Any suggestion, or a better approach will be appreciated.
Kar
<fragment>
<extension
point="org.eclipse.ui.popupMenus">
<viewerContribution
id="org.eclipse.ui.articles.action.contribution.popup.navigator "
targetID="com.xxx..views.DBView">
<action
class=" org.eclipse.ui.articles.action.contribution.ViewAction1Deleg ate "
icon="icons/command.gif"
menubarPath="additions"
id=" org.eclipse.ui.articles.action.contribution.navigator.action 1 "
label="View Action 1">
</action>
<menu
id=" org.eclipse.ui.articles.action.contribution.navigator.subMen u "
label="View Sub Menu"
path="additions">
<separator
name="group1">
</separator>
</menu>
Re: view action delegate with sub menu ... [message #332278 is a reply to message #332277] Thu, 16 October 2008 09:51 Go to previous messageGo to next message
Yes, don't use actions.
You can use org.eclipse.ui.menus to create a view submenu that contains
a dynamic contribution ... implement CompoundContributionItem and you
can return your dynamic list (I'd still suggest commands and
CommandContributionItems, but you can return ActionContributionItems if
you are so inclined).
PW
Paul Webster
Re: view action delegate with sub menu ... [message #332291 is a reply to message #332277] Fri, 17 October 2008 05:43 Go to previous messageGo to next message
Thanks Paul . it worked .
One more question if I can .
The example works fine when I add the dynamic actions to the context menu
but I would love to create a sub menu (SUB ACTION) that will be populated
with the dynamic actions.
I have tried:
a) Adding in the plugin C (the one that will display the dynamic actions) a
popup menu extension point that will just create a new menu separator .
I have tried to set the menu contribution uri to
"my.project.menu3/subseparator" with no luck (I can only see the the action2
in the sub menu) - the example works fine if I use additions in the uri.
b) Or shall I put the popup menus extension point in the plugin B - the one
where is present the db view .
c) I have even tried to create a sub menu ( in the bit of code that will
fill the context menu . ) but still I cannot add the dynamic action plus the
context menu start acting weirdly (separator appears and disappear each time
the context menu is displayed)
MenuManager viewMenu = new MenuManager("Local View", "locals");
viewMenu.add(new Separator("popuplactions"));
viewMenu.add (actionExecEomdbAction);
manager.add(viewMenu);
What am I doing wrong?
Thanks Kar
<?eclipse version="3.2"?>
<plugin>
<extension
<viewerContribution
id="my.project.viewerContribution2"
targetID="com.utils.views.DBView">
<menu
id="my.project.menu3"
label="SUB MENU"
path="additions">
<separator
name="subseparator">
</separator>
</menu>
<action
class="my.project.Action2"
id="my.project.action2"
label="label"
menubarPath="my.project.menu3/subseparator">
</action>
</viewerContribution>
</extension>
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI=" popup:com.eidosmedia.eomutils.views.EomDBView?after=addition s ">
<dynamic
class="my.project.MyCompoundContributionItem"
id="my.project.myCompoundContributionItem">
</dynamic>
</menuContribution>
</extension>
<extension
point="org.eclipse.ui.commands">
<category
id="my.project.myCategory"
name="My Category">
</category>
<command
categoryId="my.project.myCategory"
id="my.project.myCommand"
name="Do Something ">
</command>
</extension>
<extension
point="org.eclipse.ui.handlers">
<handler
class="my.project.MyHandler"
commandId="my.project.myCommand">
</handler>
</extension>
</plugin>
"Kar" <carmeloscala@hotmail.com> wrote in message
news:gd7blr$fud$1@build.eclipse.org...
> Hi all,
> of actions when selected ... the action comes from extension point (view
> action delegate)
> VIEW CONTEXT MENU
> ________________
> - Action 1
> - Action 2
> - List Action
> - sub action a
> - sub action b
> - sub action c
> - sub action d
> - Action 3
> my "List Action" action with a submenu that will list the actions (each
> one named with the name I read when the application when it starts ...)
> can override the setMenuCreator (with IMenuCreator) ...
> Thanks
> Kar
> <fragment>
> <extension
> <viewerContribution
> <action
> </action>
> <menu
> path="additions">
> <separator
> name="group1">
> </separator>
> </menu>
Re: view action delegate with sub menu ... [message #332300 is a reply to message #332278] Fri, 17 October 2008 10:48 Go to previous messageGo to next message
Paul sorry ... one more question ...
in the previous post I told you I was using the View Action Delegate to
perform my action ...
now, using the CommandContributionItem and the command handler how can I
know (or at least from where) the selected item in the view ... can I do
something similar selectionChanged ...
thanks
kar
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:gd7h92$b80$1@build.eclipse.org...
> You can use org.eclipse.ui.menus to create a view submenu that contains a
> dynamic contribution ... implement CompoundContributionItem and you can
> PW
> Paul Webster
Re: view action delegate with sub menu ... [message #332301 is a reply to message #332291] Fri, 17 October 2008 10:57 Go to previous messageGo to next message
> <plugin>
> <extension
> <viewerContribution
> <menu
> label="SUB MENU"
> path="additions">
> <separator
> </separator>
> </menu>
This needs to be in your menu contribution, since org.eclipse.ui.menus
can't see popupMenus
PW
Paul Webster
Re: view action delegate with sub menu ... [message #332302 is a reply to message #332300] Fri, 17 October 2008 10:59 Go to previous messageGo to next message
With a subclass of AbstractHandler the execution event contains the
current selection and the active part. You can use the helper methods
on HandlerUtil to get them. For popup menus, check out active menu
selection and then selection.
PW
Paul Webster
Re: view action delegate with sub menu ... [message #332305 is a reply to message #332302] Fri, 17 October 2008 11:41 Go to previous messageGo to next message
Hi Paul
hi have tried both the
HandlerUtil.getActiveMenuSelection(event)
HandlerUtil.getCurrentSelection(event)
but both are null ...
I will try to debug on Monday so I can see if I'm missing something ...
thanks again
kar
news:gda9kj$r6b$2@build.eclipse.org...
> current selection and the active part. You can use the helper methods on
> HandlerUtil to get them. For popup menus, check out active menu selection
> and then selection.
> PW
> Paul Webster
Re: view action delegate with sub menu ... [message #332306 is a reply to message #332301] Fri, 17 October 2008 11:44 Go to previous messageGo to next message
could u please be more specific ...
in the org.eclipse.ui.menus ext point I can add just MENU / WIDGET and
Group ...
ciao
kar
<extension
<menuContribution
<dynamic
</dynamic>
</menuContribution>
</extension>
news:gda9gp$r6b$1@build.eclipse.org...
> Kar wrote:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <plugin>
>> <extension
>> <viewerContribution
>> <menu
>> label="SUB MENU"
>> path="additions">
>> <separator
>> </separator>
>> </menu>
> PW
> Paul Webster
Re: view action delegate with sub menu ... [message #332357 is a reply to message #332306] Mon, 20 October 2008 07:38 Go to previous messageGo to next message
Hi Paul . solved problem about command parameters and selected item .
I still need to create the sub menu with the dynamic actions on the view
context menu .
I have tried adding the following bit to the main plugin (the one with the
view):
<extension
<menuContribution
locationURI="popup:com.utils.views.DBView?after=additions">
<menu
id="myid"
label="MyLocalAct">
<separator
name="Utils.separator1"
visible="true">
</separator>
</menu>
</menuContribution>
</extension>
And in the extending plugin use:
<extension
<menuContribution
locationURI="popup:com.utils.views.DBView?after=myid/Utils.separator1 ">
<dynamic
</dynamic>
This did not worked . (if I use just after=myid I can see the list of
commands listed in the main level of the context menu).
I did tried to put all the bit of code in the extending plugin .
<extension
<menuContribution
locationURI="popup:com.utils.views.DBView?after=addition">
<menu
id="idtest"
label="TESTTEST">
<dynamic
</dynamic>
</menu>
</menuContribution>
</extension>
No action is displayed at all.
Could u please help me
Thanks in advance
Kar
news:gdabth$5mk$1@build.eclipse.org...
> Group ...
> ciao
> kar
> <extension
> <menuContribution
> <dynamic
> </dynamic>
> </menuContribution>
> </extension>
>>> <plugin>
>>> <extension
>>> <viewerContribution
>>> <menu
>>> label="SUB MENU"
>>> path="additions">
>>> <separator
>>> </separator>
>>> </menu>
>> PW
>> Paul Webster
Re: view action delegate with sub menu ... [message #332359 is a reply to message #332305] Mon, 20 October 2008 07:52 Go to previous message
Done ... thanks :-)
http://wiki.eclipse.org/Menu_Contributions/Problems_View_Exa mple
<extension
<menuContribution
locationURI="popup:com.utils.views.EomDBView">
<separator name="group.showIn"
visible="true" />
<menu id="org.eclipse.ui.views.problems.showIn.menu"
label="ProblemView.ShowIn.label"
mnemonic="ProblemView.ShowIn.mnemonic">
<dynamic class="my.project.MyCompoundContributionItem"
id="my.project.myCompoundContributionItem"/>
</menu>
</menuContribution>
</extension>
news:gdabnf$534$1@build.eclipse.org...
> Hi Paul
> thanks again
> kar
>> PW
>> Paul Webster
Previous Topic:How do I automatically add certain *.jars to ALL projects?
Next Topic:Re: JFace Table Viewer Editor
Current Time: Fri Nov 07 11:48:06 EST 2025
Powered by FUDForum. Page generated in 0.05656 seconds
