Home » Newcomers » Newcomers » How to change compiler-compatibility to 1.5? / How to use tiger syntax?
How to change compiler-compatibility to 1.5? / How to use tiger syntax? [message #33690] Sun, 13 March 2005 12:19 Go to next message
Originally posted by: 5d7r1uo02.sneakemail.com
Hi @all!
I have installed eclipse 3.0.0 and jdk 1.5.0. Now I like to change the
compiler-compatibility mode to 1.5, unfortunately only 1.3 and 1.4 seems
to be supported.
What can I do / how can I use tiger syntax in eclipse?
Thank you.
Re: How to change compiler-compatibility to 1.5? / How to use tiger syntax? [message #33862 is a reply to message #33690] Mon, 14 March 2005 07:46 Go to previous message
Originally posted by: myersj.nospam.gmail.com
Hans,
Install Eclipse 3.1 M5. 1.5 support isn't available in Eclipse 3.0.x
- Jeff
Hans wrote:
> Hi @all!
> to be supported.
> Thank you.
Previous Topic:Building Java Application to create/edit html
Next Topic:CVS hanging
Current Time: Tue Nov 18 18:26:42 EST 2025
Powered by FUDForum. Page generated in 0.07329 seconds
