Home » Eclipse Projects » Sirius » Define Java services when the selected node
Define Java services when the selected node [message #1767073] Fri, 30 June 2017 07:59 Go to next message
I need to do some action (Java services) when selected a node.
How do I define Java services when the selected node in VSM?
Thanks.
Martin
Re: Define Java services when the selected node [message #1767173 is a reply to message #1767073] Mon, 03 July 2017 03:46 Go to previous messageGo to next message
any idea how call java services when selected node?
Thanks.
Martin
Re: Define Java services when the selected node [message #1767199 is a reply to message #1767173] Mon, 03 July 2017 09:44 Go to previous messageGo to next message
You mean by applying a tool on a node ? Sirius doesn't allow to execute tools on a simple selection. You can use the double click tool.
Florian
Re: Define Java services when the selected node [message #1767237 is a reply to message #1767199] Tue, 04 July 2017 01:24 Go to previous messageGo to next message
Hi Florian,
Thanks. I need to call an action when a node selected. Either the definition in VSM or some implementation. I understand that in VSM it is not possible (just double click), but another way?
Martin
Re: Define Java services when the selected node [message #1767443 is a reply to message #1767237] Thu, 06 July 2017 03:51 Go to previous message
Sirius does not provide API for that. You can take a look in GEF (the framework with GMF on which Sirius rely on) how SWT events are handled (http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.gef.doc.isv%2Fguide%2Fguide.html). The mehod org.eclipse.gef.tools.SelectionTool.mouseDown(MouseEvent, EditPartViewer) is a good entry point.
Florian
Previous Topic:Rotate (re-layout) the diagram to 90 degrees.
Next Topic:Runtime no longer opens .odesigns from newer specification version
Current Time: Tue Jul 15 13:36:57 EDT 2025
Powered by FUDForum. Page generated in 1.82515 seconds
