Home » Eclipse Projects » Eclipse Platform » Is there an event for generating getters/setters?
Is there an event for generating getters/setters? [message #332185] Wed, 08 October 2008 19:13
I'm trying to get into the "EclipseMonkey" feature, now "Aptana
Scripting". part of this allows attaching listeners to events. The hard
part is knowing what objects can fire events that I can attach listeners
to. For instance, I'm trying to determine whether there's an event
specifically fired when the user generates code from the "Generate
Getters/Setters" dialog. Is this possible. Where would I find out about
this? I've already read all the EclipseMonkey documentation.
Previous Topic:Error after updating process
Next Topic:using command handlers to enable/disable push buttons
Current Time: Fri Nov 21 05:53:24 EST 2025
Powered by FUDForum. Page generated in 0.03201 seconds
