Home » Eclipse Projects » Eclipse Platform » SelectionChanged(IAction.., ISelection..)
SelectionChanged(IAction.., ISelection..) [message #332169] Wed, 08 October 2008 08:02 Go to next message
I want to enable/disable toolbar action using action.setEnabled()
method.But SelectionChanged() is only called at eclipse startup. And
afterwards , this method is not called.Hence, the button never gets
disabled.
public void SelectionChanged(IAction action, ISelection selection){
if(count%2 ==0)
action.setEnabled(true);
else
action.setEnabled(false);
Sana.
Re: SelectionChanged(IAction.., ISelection..) [message #332170 is a reply to message #332169] Wed, 08 October 2008 08:16 Go to previous messageGo to next message
Sana,
You extended BaseSelectionListenerAction and specialized
updateSelection? (You could use action.setEnabled(count%2 ==0) for more
compact code.)
sana wrote:
> disabled.
> if(count%2 ==0)
> else
> Sana.
Re: SelectionChanged(IAction.., ISelection..) [message #332190 is a reply to message #332170] Thu, 09 October 2008 03:08 Go to previous messageGo to next message
No...how do i do that?
Sana
Re: SelectionChanged(IAction.., ISelection..) [message #332193 is a reply to message #332190] Thu, 09 October 2008 06:56 Go to previous message
Sana,
Eclipse is full of source code that you can look at to see how others
have implemented something similar to what you're trying to do. Take
advantage of the ability to search the Eclipse site for information
related to what you're interested in...
> Sana
Previous Topic:ISearchQuery.run(IProcessMonitor) ,how is it get called??
Next Topic:Problem with BasicNewProjectResourceWizard
Current Time: Sun Jul 27 03:14:53 EDT 2025
Powered by FUDForum. Page generated in 0.06150 seconds
