| File ..ROOT...override [message #33673] |
Thu, 29 April 2004 03:44  |
Originally posted by: th.huebner.sap.corp
In plugin org.eclipse.jem exists a file called ..ROOT...override.
Through the three dots in the filename it's inpossible to check
in this file into Perforce. In Perforce three dots are reserved for
wildcards.
Is it possible to rename such files? What is the reason for this
naming convention?
Best Regards,
Thomas
| Re: File ..ROOT...override [message #35744 is a reply to message #33824] |
Wed, 05 May 2004 10:28  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Will .ROOT.override cause a problem? If it doesn't, then please open a
bugzilla bug against VE JEM component to have them renamed to that.
Rich Kulp wrote:
> It's a special file, it is named that way so that it willbe unique and
> not likely to collide with any other file that someone may place out there.
Thanks, Rich Kulp
| Re: File ..ROOT...override [message #587510 is a reply to message #33719] |
Thu, 29 April 2004 14:17  |
Thanks, Rich Kulp
| Re: File ..ROOT...override [message #588155 is a reply to message #33824] |
Thanks, Rich Kulp
FUDForum. Page generated in 0.04359 seconds
