Home » Eclipse Projects » Eclipse Platform » ISearchQuery.run(IProcessMonitor) ,how is it get called??
ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332119] Mon, 06 October 2008 05:38 Go to next message
Hi ,
I am working on a specialized search plug-in in eclipse.Can somebody here
tell me when is the run() method from ISearchQuery is called.I have
implemented ISearchQuery but my system is unable to invoke run() in it.
thanks,
Rahul.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332124 is a reply to message #332119] Mon, 06 October 2008 06:56 Go to previous messageGo to next message
Rahul Yadav wrote:
> Hi ,
> here tell me when is the run() method from ISearchQuery is called.I
> have implemented ISearchQuery but my system is unable to invoke run()
> in it.
Normally you also provide a corresponding search dialog page. In the
performAction() method of that page you would call something like:
NewSearchUI.runQueryInBackground(yourQuery);
Dani
> thanks,
> Rahul.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332134 is a reply to message #332124] Mon, 06 October 2008 12:22 Go to previous messageGo to next message
that is true...i am calling it with ISearchQuery.Here is the snippet...
NewSearchUI.runQueryInBackground(newQuery1());
private ISearchQuery newQuery1() throws CoreException {
ISearchQuery query;
NewSearchData searchRelatedData=new NewSearchData(fContainer);
query=new NewICSearchQuery(searchRelatedData);
return query;
NewICSearchQuery.java
public IStatus run(IProgressMonitor monitor)
throws OperationCanceledException {
IRunnableWithProgress query=new NewType(searchData);
try{
searchData.getFContainer().getRunnableContext().run(true, true,
query);
}catch(Exception e){}
return null;
Thanks.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332135 is a reply to message #332134] Mon, 06 October 2008 12:27 Go to previous messageGo to next message
> ISearchQuery query;
> return query;
> try{
> query);
> return null;
> Thanks.just to add some more info....
ISearchQuery.getSearchResult() is repeatedly getting called infinitely
until i close the search dialog.
I don't know how are they related !!!!
Thanks.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332148 is a reply to message #332135] Tue, 07 October 2008 03:15 Go to previous messageGo to next message
>> ISearchQuery query;
>> return query;
>> try{
>> true, query);
>> return null;
> infinitely until i close the search dialog.
It looks like yo also start it in your code:
query);
This is wrong as NewSearchUI.runQueryInBackground(...) already does this.
Dani
> Thanks.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332150 is a reply to message #332148] Tue, 07 October 2008 08:29 Go to previous messageGo to next message
That was for different purpose, i can remove it.They are written in
implemented run method,those statement will execute only if run method
gets called...but the real problem is ISearchQuery.run(IProcessMonitor)
this is not getting invoked.
Thanks.
Re: ISearchQuery.run(IProcessMonitor) ,how is it get called?? [message #332192 is a reply to message #332150] Thu, 09 October 2008 04:30 Go to previous message
> ISearchQuery.run(IProcessMonitor) this is not getting invoked.
If you call NewSearchUI.runQueryInBackground(yourQuery) as advised
before then this will trigger ISearchQuery.run(...) or something is
completely broken in your code or setup. If it still doesn't work I
suggest to debug into
org.eclipse.search2.internal.ui.InternalSearchUI.runSearchIn Background(ISearchQuery,
ISearchResultViewPart).
Dani
> Thanks.
Previous Topic:Duplicate template proposals prevent automatic insertion
Next Topic:SelectionChanged(IAction.., ISelection..)
Current Time: Mon Dec 01 20:10:22 EST 2025
Powered by FUDForum. Page generated in 0.05601 seconds
