Home » Eclipse Projects » Eclipse Platform » Launching external executable?
Launching external executable? [message #332118] Mon, 06 October 2008 03:34 Go to next message
For a certain scenario I need to launch an external executable (*.exe)
from within an RCP application.
I also need to have control of the launched process, e.g. get return
status etc.
Which is the most suiteable and recommended approach for this?
I've searched a lot about launching and basically all I've found deals
with Eclipse launch framework (i.e. creating ILaunchConfigurationType,
ILaunchConfiguration...).
But isn't this approach more applicable for run/debug activities during
development?
Or if needed to provide run/debug launch configuration UI to user?
Because this is not the case for me. I just need to launch an executable
and have proper control for that launched process.
BTW. I'm running on Windows platform.
Thanks in advance, need a quick answer!
Joachim
Re: Launching external executable? [message #332121 is a reply to message #332118] Mon, 06 October 2008 06:02 Go to previous messageGo to next message
Joachim Rietz wrote:
> status etc.
> development?
I would have tried Runtime#exec. The return type is a Process object,
which has e.g. a method waitFor and a method exitValue....
HTH,
Daniel Krügler
Re: Launching external executable? [message #333123 is a reply to message #332121] Wed, 26 November 2008 05:41 Go to previous message
Originally posted by: luimarr1.upvnet.upv.es
>> status etc.
>> during development?
>> executable and have proper control for that launched process.
> HTH,
> Daniel Krügler
Hi Daniel,
i did it not long ago and found some trouble that finally solved
reading this article:
http://www.javaworld.com/javaworld/jw-12-2000/jw-1229-traps. html?page=3
regards,
Luis
Previous Topic:DB-plugin with visualisation?
Next Topic:Syntax Highlighting Rules for Custom Editor
Current Time: Tue Nov 18 13:49:22 EST 2025
Powered by FUDForum. Page generated in 0.03333 seconds
