Home » Eclipse Projects » Eclipse Platform » register a listener at workbench/plugin start
register a listener at workbench/plugin start [message #332105] Fri, 03 October 2008 04:20 Go to next message
Hi!
What is the best to way to make a plugin that registers a selection
listener in a view from another plugin just as it starts?
Note that I want this plugin to start imediatly afert the workbench
starts, but i cannot register the selection listener in the start() or
earlyStart() methods since there is no SelectionService yet.
André
Re: register a listener at workbench/plugin start [message #332114 is a reply to message #332105] Sat, 04 October 2008 01:37 Go to previous messageGo to next message
Workbench provide a listener which provide event when workbench window
opening. Using this, you can make delayed activator.
André Ribeiro wrote:
> Hi!
> Cheers,
> André
Re: register a listener at workbench/plugin start [message #332123 is a reply to message #332114] Mon, 06 October 2008 06:52 Go to previous messageGo to next message
could you point me where is it?
i just could find this one
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/reference/api/org/eclipse/ui/IWorkbenchListener.html
wich only has methods for shutdown events ...
>> Hi!
>> or earlyStart() methods since there is no SelectionService yet.
>> Cheers,
>> André
Re: register a listener at workbench/plugin start [message #332144 is a reply to message #332123] Mon, 06 October 2008 22:22 Go to previous message
These are codes of mine. So remember, It is not given from eclipse, so
you may can't trust this method.
Plugin Activator codes:
public void start(BundleContext context) throws Exception {
super.start(context);
this.dynamicStateInitializer =
new DynamicCommandStateManager(getWorkbench());
dynamicStateInitializer.activate();
plugin = this;
DynamicCommandStateManager.activate():
public final void activate() {
IWorkbenchWindow window = workbench.getActiveWorkbenchWindow();
// What if workbench is ready, just activating now.
if (window != null) {
this.window = window;
_activate();
// If there is no Workbench window,
// register listener which will acitvate later.
else {
workbench.addWindowListener(delayedActivator);
>>> Hi!
>>> Cheers,
>>> André
Previous Topic:Proper way to identify editor lifecycle events?
Next Topic:HTML2TextReader class
Current Time: Sun Nov 23 03:50:03 EST 2025
Powered by FUDForum. Page generated in 0.05441 seconds
