Home » Eclipse Projects » Remote Application Platform (RAP) » Rap running in RCP
Rap running in RCP [message #33658] Sat, 16 June 2007 22:59 Go to next message
Originally posted by: ztw.powersail.com.cn
Can RAP running in RCP application,rap run as a rcp's service?
And rcp plugins has web entrypoints and desktop UI.
Re: Rap running in RCP [message #33693 is a reply to message #33658] Sun, 17 June 2007 13:39 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Tim,
(without actually having tried it)
in theory yes, but since the namespace switch in M4 not any more.
Eclipse - and so would your RCP app - refuses to start properly because
it gets confused with the extension points of the same name. BTW,
because of this we provide M5 as a target platform.
There might be a chance that this behavior is considered a bug and gets
fixed in the future.
Rüdiger
Re: Rap running in RCP [message #33726 is a reply to message #33693] Sun, 17 June 2007 13:48 Go to previous messageGo to next message
There was a mistake in the previous post, see below. Sorry for the that.
Rüdiger Herrmann wrote:
> Hi Tim,
[...] provide *M4* as a target [...]
(but M5 probably as well, unless there comes up a better way)
> Cheers,
> Rüdiger
Re: Rap running in RCP [message #41113 is a reply to message #33693] Mon, 30 July 2007 17:06 Go to previous messageGo to next message
I thought about this too. How would the following idea work: I repackage
the RAP distribution in a bundle "raprepackaged". The RCP UI would
depend on org.eclipse.ui and the usual SWT etc. bundles. The RAP UI
would depend on the raprepackaged bundle. It would get the RAP classes
using the SWT namespace. My assumption is that all plug-ins use the
"old-fashioned" Require-Bundle mechanism, not the Import-Package mechanism.
Would this work?
Or, under the assumption that SWT is at version 3.3 and RAP at 1.0,
would it work to define these version numbers in the plug-in
dependencies to distinguish them?
Frank.
Re: Rap running in RCP [message #41236 is a reply to message #41113] Tue, 31 July 2007 16:38 Go to previous messageGo to next message
Hi Frank,
did you give it a try? From what I know, this won't work. The reason why
we are providing target platform downloads instead of update-sites plays
in the same field.
The extension registry gets confused when two (differently named)
plug-ins provide an extension point of the same name.
Rüdiger
> Would this work?
> Frank.
Re: Rap running in RCP [message #41266 is a reply to message #41236] Tue, 31 July 2007 17:16 Go to previous message
Rüdiger Herrmann schrieb:
> Hi Frank,
> in the same field.
No, I didn't try it. You are right, the extension registry will get
confused. Too bad. Hmm.
Frank.
Previous Topic:RWT extension
Next Topic:Debug RAP demo app
Current Time: Sat Nov 08 00:06:16 EST 2025
Powered by FUDForum. Page generated in 0.05055 seconds
