Home » Eclipse Projects » Eclipse Platform » Building Eclipse 3.4.1 From Source Fails
Building Eclipse 3.4.1 From Source Fails [message #332067] Wed, 01 October 2008 17:54 Go to next message
Greetings,
I am trying to compile Eclipse 3.4.1 from source and am running into a
series of compile errors. Everything appears to be compiling fine when it
reaches the org.eclipse.osgi plugin. There, it ends up throwing over
12,659 errors. I have attached the first couple to this message. I
followed instructions.html and am using the build.properties from Eclipse
3.4, which compiles fine. Any help would be appreciated, thanks.
Bryan
The system specs are:
HP xw6200
RedHat Enterprise Workstation 5.2
My build.properties:
J2SE-1.4=/home/user/java/j2sdk1.4.2_18/jre/lib/rt.jar;/home/ user/java/j2sdk1.4.2_18/jre/lib/jsse.jar;/home/user/java/j2s dk1.4.2_18/jre/lib/jce.jar
J2SE-1.5=/home/user/java/jdk1.5.0_16/jre/lib/rt.jar;/home/us er/java/jdk1.5.0_16/jre/lib/jsse.jar;/home/user/java/jdk1.5. 0_16/jre/lib/jce.jar
JavaSE-1.6=/home/user/java/jdk1.6.0_07/jre/lib/rt.jar;/home/ user/java/jdk1.6.0_07/jre/lib/jsse.jar;/home/user/java/jdk1. 6.0_07/jre/lib/jce.jar
First part of the error output:
# 10/1/08 8:09:48 PM UTC
# Eclipse Java Compiler 0.871, 3.4.0 release candidate-3, Copyright IBM
Corp 2000, 2008. All rights reserved.
1. ERROR in
/tmp/source/plugins/org.eclipse.osgi/osgi/src/org/osgi/frame work/AdminPermission.java
(at line 1)
The type java.lang.Object cannot be resolved. It is indirectly referenced
from required .class files
2. ERROR in
(at line 1)
The type java.lang.String cannot be resolved. It is indirectly referenced
3. ERROR in
(at line 21)
import java.io.IOException;
The import java.io cannot be resolved
4. ERROR in
(at line 22)
import java.security.*;
The import java.security cannot be resolved
Re: Building Eclipse 3.4.1 From Source Fails [message #332090 is a reply to message #332067] Thu, 02 October 2008 11:23 Go to previous messageGo to next message
Bryan,
Take a peek at the org.eclipse.osgi/build.xml file:
The javac call in the @dot target uses
bootclasspath="${bundleBootClasspath}"
At the top, we see the property being set:
<property name="bundleBootClasspath"
value=" osgi/exceptions.jar;osgi/xmlParserAPIs.jar;${CDC-1.0/Foundat ion-1.0} "/>
The CDC-1.0/Foundation-1.0 is similar to the other bootclasspath
properties you are already setting (ie J2SE-1.4). You can either get a
vm for that environment (http://wiki.eclipse.org/J9), or I think you can
probably get away with using 1.5:
CDC-1.0/Foundation-1.0=${J2SE-1.5}
-Andrew
Bryan Rockwood wrote:
> Greetings,
> it reaches the org.eclipse.osgi plugin. There, it ends up throwing over
> Eclipse 3.4, which compiles fine. Any help would be appreciated, thanks.
> Bryan
> HP xw6200
> 1. ERROR in
> (at line 1)
> referenced from required .class files
> 2. ERROR in
> (at line 1)
> 3. ERROR in
> (at line 21)
> 4. ERROR in
> (at line 22)
Re: Building Eclipse 3.4.1 From Source Fails [message #332096 is a reply to message #332090] Thu, 02 October 2008 14:37 Go to previous messageGo to next message
Andrew,
Thank you for your help; that fixed the problem!
Bryan
Andrew Niefer wrote:
> Bryan,
> -Andrew
>> Greetings,
>> Bryan
>> HP xw6200
>> 1. ERROR in
>> (at line 1)
>> 2. ERROR in
>> (at line 1)
>> 3. ERROR in
>> (at line 21)
>> 4. ERROR in
>> (at line 22)
Re: Building Eclipse 3.4.1 From Source Fails [message #332310 is a reply to message #332096] Fri, 17 October 2008 13:43 Go to previous message
Originally posted by: amir.nospam_pyrus.us
How are you setting 'CDC-1.0/Foundation-1.0=${J2SE-1.5}'? Is this an
environment variable setting, or is this a property setting in the
'.../plugins/org.eclipse.osgi/build.xml' file?
Please provide some details.
Thanks.
Amir
> Andrew,
> Bryan
>> Bryan,
>> a vm for that environment (http://wiki.eclipse.org/J9), or I think you
>> can probably get away with using 1.5:
>> -Andrew
>>> Greetings,
>>> a series of compile errors. Everything appears to be compiling fine
>>> when it reaches the org.eclipse.osgi plugin. There, it ends up
>>> throwing over 12,659 errors. I have attached the first couple to
>>> this message. I followed instructions.html and am using the
>>> build.properties from Eclipse 3.4, which compiles fine. Any help
>>> Bryan
>>> HP xw6200
>>> IBM Corp 2000, 2008. All rights reserved.
>>> 1. ERROR in
>>> (at line 1)
>>> 2. ERROR in
>>> (at line 1)
>>> 3. ERROR in
>>> (at line 21)
>>> 4. ERROR in
>>> (at line 22)
Previous Topic:How to list all (non-default) remote feature site currently added?
Next Topic:commands contribution ...
Current Time: Mon Jul 21 22:20:29 EDT 2025
Powered by FUDForum. Page generated in 0.29071 seconds
