Home » Eclipse Projects » Eclipse Platform » Custom install handler not getting run with Eclipse 3.4
Custom install handler not getting run with Eclipse 3.4 [message #332034] Wed, 01 October 2008 12:11 Go to next message
I have a custom install handler for my plugin. This all works fine in Eclipse 3.2. Moving
to Eclipse 3.4 my custom install handler never gets run during install. My feature and
plugin get downloaded from the update site but the custom install handler never runs.
Here is a snippet from my feature.xml:
<feature
id="com.ibm.auiml.toolkit.install"
label="AUIML Toolkit"
version="7.1.1.0809290408"
provider-name="IBM"
os="aix,hpux,linux,macosx,qnx,solaris,win32"
ws="win32,gtk"
nl="en">
<install-handler library="installtools.jar"
handler="com.ibm.auiml.toolkit.AuimlInstallHandler"/>
Any ideas why this wouldn't work anymore on Elcipse 3.4?
Andy Arhelger
Re: Custom install handler not getting run with Eclipse 3.4 [message #332048 is a reply to message #332034] Wed, 01 October 2008 14:56 Go to previous messageGo to next message
p2 doesn't support install handlers. When detected, though, they're
supposed to offer the user the option to switch to the old Update
Manager (which will run the install handlers).
Are you doing a headless install? Are there any errors in the workspace
of the eclipse you are trying to update? <workspace>/.metadata/.log
PW
Paul Webster
Re: Custom install handler not getting run with Eclipse 3.4 [message #332057 is a reply to message #332048] Wed, 01 October 2008 15:57 Go to previous messageGo to next message
No I am not doing a headless install, normal Help -> Software Updates...
(I am running RAD 7.5)
Don't see any errors in the .log file that pertain to the install. I will try again and
clear the log first.
Andy Arhelger
> PW
Re: Custom install handler not getting run with Eclipse 3.4 [message #332061 is a reply to message #332048] Wed, 01 October 2008 16:28 Go to previous messageGo to next message
Paul:
No, don't see any exceptions in the log and it didn't ask me if I wanted to use the old
Update Manager.
Is there anyway to force my install to use the old Update Manager?
Andy Arhelger
> PW
Re: Custom install handler not getting run with Eclipse 3.4 [message #332083 is a reply to message #332061] Thu, 02 October 2008 08:30 Go to previous messageGo to next message
Andy Arhelger wrote:
> Paul:
> to use the old Update Manager.
This sounds like a bug, please open a bug at
https://bugs.eclipse.org/bugs/ against RT Equinox P2 (Equinox is no
longer under Eclipse). It's a serious problem if the Install Handlers
are not causing a switch to the old Update Manager.
Yes, go to Window>Preferences>General>Capabilities and activate Classic
Update. Then there should be the old Software Updates> submenu as well.
PW
Paul Webster
Re: Custom install handler not getting run with Eclipse 3.4 [message #332088 is a reply to message #332083] Thu, 02 October 2008 11:13 Go to previous message
Paul:
Thanks. I will open a problem.
I did find the Capabilities option and turned on the Classic Update Manager. When I
installed using the Classic Update Manager it did work for me.
Andy Arhelger
>> Paul:
>> wanted to use the old Update Manager.
> PW
Previous Topic:enable command handler on startup
Next Topic:display whitespace toggle shortcut
Current Time: Wed Jul 16 00:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.24609 seconds
