Home » Eclipse Projects » Eclipse Platform » unable to uninstall plugin with p2
unable to uninstall plugin with p2 [message #331987] Wed, 01 October 2008 04:56 Go to next message
hello,
I added a plugin using the dropin feature:
eclipse/dropins/myplugin/eclipse|
features/..
pluglins/..
then I tried to unsinstall it:
1) tried using software updates, but when I select the feature the
unistall button is not active
2) removed from dropins, but when I restart eclipse the plugin is still
there (where...?)
I need to uninstall it else I must downgrade to 3.3 sob :-(
thanks,
Luca
Re: unable to uninstall plugin with p2 [message #331999 is a reply to message #331987] Wed, 01 October 2008 08:49 Go to previous messageGo to next message
On 10/1/2008 4:56 AM, Luca Di Stefano wrote:
> hello,
> features/..
> pluglins/..
> there (where...?)
Try restarting Eclipse with the -clean option after you remove a plugin
from the dropins folder.
Hope this helps,
Eric
Re: unable to uninstall plugin with p2 [message #332004 is a reply to message #331999] Wed, 01 October 2008 09:25 Go to previous message
perfect thanks!
the other solution was upgrade the plugin using software updates, then the
uninstall button became available.
but your solution is better obviously!
Previous Topic:Extending DeleteResourceAction
Next Topic:Question about extension-point org.eclipse.ui ViewActions
Current Time: Fri Nov 21 20:21:21 EST 2025
Powered by FUDForum. Page generated in 0.25126 seconds
