Home » Eclipse Projects » Eclipse Platform » Unable to register Search Extension to search extension point.
Unable to register Search Extension to search extension point. [message #331985] Wed, 01 October 2008 02:38 Go to next message
Hi, My assignment is to develop our own specific search and to add this
option on Eclipse search Dialog. After reading through docs i found that
it requires me to develop search extension plug-in.I have written a
plug-in and copied it to \eclipse\plugin folder. After restarting the
eclipse i was expecting to see a new tab in search dialog but i don't see
it. i tried to programaticaly list the extensions under Search Extension
point there also i don't see the new extension i have added although list
all other three extension that come with my eclipse. It will be a big help
if somebody on the list can provide me any hint on this.
Re: Unable to register Search Extension to search extension point. [message #331994 is a reply to message #331985] Wed, 01 October 2008 06:55 Go to previous message
> this option on Eclipse search Dialog. After reading through docs i
> found that it requires me to develop search extension plug-in.I have
> written a plug-in and copied it to \eclipse\plugin folder.
Which Eclipse version? If you are using 3.4 or new then you must put it
into the dropins folder.
Dani
> After restarting the eclipse i was expecting to see a new tab in
> search dialog but i don't see it. i tried to programaticaly list the
> extensions under Search Extension point there also i don't see the new
> extension i have added although list all other three extension that
> come with my eclipse. It will be a big help if somebody on the list
Previous Topic:IMarker - problem view and editor
Next Topic:How to disable Welcome view when running/debugging eclipse plug-in
Current Time: Thu Nov 06 21:04:08 EST 2025
Powered by FUDForum. Page generated in 0.10291 seconds
