Home » Eclipse Projects » Eclipse Platform » Re: Error launching the preference page
Re: Error launching the preference page [message #331939] Tue, 30 September 2008 01:33 Go to next message
I'm not getting any exception. Is there are any specific steps to reproduce
the issue?
- Prakash
http://blog.eclipse-tips.com
"G Dev" <gdind2003@gmail.com> wrote in message
news:48E1439E.9020107@gmail.com...
> Hi Prakash,
> I am giving the stack trace and also the src zip file. It is available
> in the project as well.
> java.lang.NullPointerException
> at
> org.fastcode.preferences.CreateSimilarPreferencePage.perform Ok(CreateSimilarPreferencePage.java:329)
> at
> org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:926)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:857)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
> at
> org.eclipse.jface.preference.PreferenceDialog.okPressed(Pref erenceDialog.java:906)
> at
> org.eclipse.jface.preference.PreferenceDialog.buttonPressed( PreferenceDialog.java:233)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:618)
> Thanks for help,
> --Gautam
> Prakash G.R. wrote:
>> Gautam,
>> Attaching the stack trace/the few lines of source where NPE occurs
>> might be useful for others who try to investigate this issue. BTW, are
>> you passing the right parent for the Field Editors?
>> - Prakash
Re: Error launching the preference page [message #331965 is a reply to message #331939] Tue, 30 September 2008 13:07 Go to previous messageGo to next message
Originally posted by: gdind2003.gmail.com
Prakash,
I don't know how you tried. It works from Windows->Preferences. But if I
launch it in the middle of the program when I don't find a match and I
want to take the user directly to the preference page error occurs.
I can see the preference diaglog fine and I get NPE when I click OK.
--Gautam
> reproduce the issue?
> - Prakash
Re: Error launching the preference page [message #332210 is a reply to message #331965] Fri, 10 October 2008 11:45 Go to previous messageGo to next message
I am disappointed to get no answer on this. This is killing me.
Could anyone take a look at this.
Thanks in advance,
--Gautam
G Dev wrote:
> Prakash,
> --Gautam
>> - Prakash
Re: Error launching the preference page [message #332211 is a reply to message #332210] Fri, 10 October 2008 12:17 Go to previous messageGo to next message
Did you provide a stack trace of the NPE exception ?
Without this, I don't see what we can check or look at.
Olivier
Re: Error launching the preference page [message #332213 is a reply to message #332211] Fri, 10 October 2008 12:53 Go to previous messageGo to next message
The stack trace was provided in an earlier post. Also the source files
attached before.
--Gautam
> Olivier
Re: Error launching the preference page [message #332214 is a reply to message #332213] Fri, 10 October 2008 13:19 Go to previous messageGo to next message
> attached before.
Sorry I missed it.
> at
> at
You have a bundle that provides a boggus preference page. I would
contact the provider of the
org.fastcode.preferences.CreateSimilarPreferencePage class.
Olivier
Re: Error launching the preference page [message #332215 is a reply to message #332214] Fri, 10 October 2008 13:27 Go to previous messageGo to next message
It is actually my plugin which works fine when opened from Windows ->
Preference. But it gives error when launched by itself.
--Gautam
>> attached before.
> Sorry I missed it.
>> at
>> at
> Olivier
Re: Error launching the preference page [message #332238 is a reply to message #332215] Tue, 14 October 2008 03:47 Go to previous messageGo to next message
Hi Gautam,
I took a quick look at your code. You should not directly create the
dialog. Instead use
org.eclipse.ui.dialogs.PreferencesUtil.createPreferenceDialo gOn(Shell,
String, String[], Object)
HTH
Dani
> --Gautam
>>> files attached before.
>> Sorry I missed it.
>>> at
>>> at
>> Olivier
Re: Error launching the preference page [message #332281 is a reply to message #332238] Thu, 16 October 2008 13:22 Go to previous messageGo to next message
--------------080808050307040601010604
Thanks. That worked much better. What do you pass as the last argument?
I put null and it worked. Only one problem, my fast code main preference
page is coming as blank as shown in the attachment.
--Gautam
> Hi Gautam,
> dialog. Instead use
> HTH
> Dani
>> Thanks,
>> --Gautam
>>> G Dev a
Re: Error launching the preference page [message #332292 is a reply to message #332281] Fri, 17 October 2008 08:53 Go to previous messageGo to next message
This is optional. We sometimes pass in context that the page then uses
to select a concrete setting on the page.
Dani
> preference page is coming as blank as shown in the attachment.
> --Gautam
>>> -> Preference. But it gives error when launched by itself.
>> Hi Gautam,
>> dialog. Instead use
>> HTH
>> Dani
>>> Thanks,
>>> --Gautam
>>>> Sorry I missed it.
>>>>> at
>>>>> at
>>>> Olivier
Re: Error launching the preference page [message #332365 is a reply to message #332292] Mon, 20 October 2008 10:52 Go to previous messageGo to next message
Thanks. I wonder what the PreferenceUtil does that other method does
not. Any idea why the first page is coming blank?
--Gautam
> Dani
>> Thanks,
>> --Gautam
>>> Hi Gautam,
>>> dialog. Instead use
>>> HTH
>>> Dani
>>>> Thanks,
>>>> --Gautam
>>>>> Sorry I missed it.
>>>>>> at
>>>>>> at
>>>>> Olivier
Re: Error launching the preference page [message #332500 is a reply to message #332365] Thu, 23 October 2008 11:10 Go to previous message
No idea. If you can reproduce then you should file a bug with a test case.
Dani
> --Gautam
>> uses to select a concrete setting on the page.
>> Dani
>>> Thanks,
>>> --Gautam
>>>> Hi Gautam,
>>>> the dialog. Instead use
>>>> HTH
>>>> Dani
>>>>> Thanks,
>>>>> --Gautam
>>>>>> Sorry I missed it.
>>>>>>> at
>>>>>>> at
>>>>>> Olivier
Previous Topic:Marker Annotations disapperaring in vertical toolbar
Next Topic:Databinding - DirtyState of an BindingContext
Current Time: Mon Jul 21 21:24:06 EDT 2025
Powered by FUDForum. Page generated in 0.06284 seconds
