Home » Eclipse Projects » Eclipse Platform » IMarker - problem view and editor
IMarker - problem view and editor [message #331936] Mon, 29 September 2008 22:06 Go to next message
I have written a new implementation of a debugger and editor for Lua.
I was trying to set an "Error" IMarker in the editor.
I set an IMarker and the marker shows up in the "Problems view" but not in
the editor. How can I get it to appear in both?
Here is the code I set the marker with.
IWorkspaceRunnable editorMarker = new IWorkspaceRunnable() {
public void run(IProgressMonitor monitor) throws CoreException {
IMarker marker =
ResourcesPlugin.getWorkspace().getRoot().
createMarker(IMarker.PROBLEM);
marker.setAttribute(IMarker.MESSAGE, msg);
marker.setAttribute(IMarker.LINE_NUMBER, lineNumber);
marker.setAttribute(IMarker.TRANSIENT, true);
marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_ERROR);
try {
ResourcesPlugin.getWorkspace().run(editorMarker, null);
} catch (CoreException e) {
System.err.println("Some error set marker: " + e);
Re: IMarker - problem view and editor [message #331945 is a reply to message #331936] Tue, 30 September 2008 03:45 Go to previous messageGo to next message
> not in the editor. How can I get it to appear in both?
> IMarker marker = ResourcesPlugin.getWorkspace().getRoot().
This is wrong. You need to create the marker on the resource that's
shown in the editor.
Dani
> try {
Re: IMarker - problem view and editor [message #331972 is a reply to message #331945] Tue, 30 September 2008 15:36 Go to previous messageGo to next message
Thanks for your help.
Can getting the resource be done with static calls to get the resource (I
don't have the IRresource when I am trying to make a marker because I have
only a file name path that is given back from the Lua interpreter).
For example using:
ResourcesPlugin.getWorkspace() ...
In my line break point code, I am given a IWorkBechPart, from which I can
get my text editor:
public void toggleLineBreakpoints(IWorkbenchPart part, ISelection
selection) throws CoreException {
ITextEditor textEditor = getEditor(part);
IResource resource = (IResource)
editorPart.getEditorInput().getAdapter(IResource.class);
But I believe you are referring to the file resource that I have
interpreted to find the Lua syntax error in the editor, correct?
> Dani
>> try {
Re: IMarker - problem view and editor [message #331992 is a reply to message #331972] Wed, 01 October 2008 06:54 Go to previous message
> (I don't have the IRresource when I am trying to make a marker because
> I have only a file name path that is given back from the Lua
> interpreter).
> For example using:
> can get my text editor:
Right. At the point you add the marker you need to resolve the correct
resource otherwise it won't show up in the editor.
Dani
>>> IMarker marker =
>> Dani
>>> try {
Previous Topic:JVM terminated. Exit code 13
Next Topic:Unable to register Search Extension to search extension point.
Current Time: Mon Jul 21 21:56:11 EDT 2025
Powered by FUDForum. Page generated in 1.04401 seconds
