Home » Eclipse Projects » Eclipse Platform » ActiveEditorId Expression
ActiveEditorId Expression [message #331920] Mon, 29 September 2008 10:03 Go to next message
I am trying to use expressions to enable/disable (ie set visible/not
visible) menu entries when certain conditions are met. Basically we have a
"profile" which is a bit like a set of preferences and allows users to
turn off certain behaviours.
I have created my own PropertyTester, but I am having a bit of trouble.
The configuration for the propertyTester requires a "type" which I have
set to ...IResource. This works fine when the current selection is an item
in the explorer - although I never use the actual resource.
When the user opens an editor however the propertyTester no longer works.
In fact everything then gets "false" and all of the menu/toolbar items
using this propertyTester disappear!
How can I set up a propertyTester to be used irrespective of the current
selection/ active Editor ?
(At least I think that's the right question !!!!)
Richard
Re: ActiveEditorId Expression [message #332011 is a reply to message #331920] Wed, 01 October 2008 09:45 Go to previous message
Richard Craddock wrote:
> a "profile" which is a bit like a set of preferences and allows users to
Well, the type you pick depends on what menus you wish your contribution
to appear in. Where do you want them? Do you really care about the
current selection, or you expect them to appear in every popup
(controlled by the profile)?
If the second is true, 2 potential solutions are 1) tie your PT to
java.lang.Object, although I don't really recommend this or 2) tie your
PT to org.eclipse.ui.IWorkbenchPart and use it like:
<visibleWhen>
<with variable="activePart">
<test ...whatever.../>
</with>
</visibleWhen>
[/xml]
Later,
PW
Paul Webster
Previous Topic:Default configuration for dev environment
Next Topic:What's the difference between IEditorSite and IEditorPart
Current Time: Sun Aug 31 02:34:22 EDT 2025
Powered by FUDForum. Page generated in 0.03779 seconds
