Home » Eclipse Projects » Eclipse Platform » new debugger implementation - changing default names
new debugger implementation - changing default names [message #331885] Fri, 26 September 2008 09:58
I have implemented a debugger for the Lua language.
I started with the exercises from "How to Write a Debugger" at:
http://www.eclipse.org/articles/Article-Debugger/how-to.html
I have everything working in this Lua debugger, from variable display to
breakpoints.
There are a few things I would like to change.
For example, there is a "Java Perspective" that I use to create projects,
etc. This is part of the default debugger framework.
How can I change the name of this perspective from "Java Perspective" to
"Lua Perspective"?
There is also a banner across the top of the debugger that has text like:
"Java prog.lua - Eclipse SDK
Do I have access to these plugin text fields to modify them?
John
Previous Topic:Resource synchronize problem
Next Topic:"problems view" opening on new problems
Current Time: Sat Nov 15 04:02:08 EST 2025
Powered by FUDForum. Page generated in 0.03361 seconds
