Home » Eclipse Projects » Eclipse Platform » Re: Updating to 3.4.1
Re: Updating to 3.4.1 [message #331863] Thu, 25 September 2008 11:44 Go to next message
Originally posted by: codeslave.ca.ibm.com
Copying to eclipse.platform and eclipse.technology.equinox newsgroups.
Ian Leslie wrote:
> While not really a new comer I do have a newby type question. Now that
> 3.4.1 has been released will I be able to use the update mechanism to
> update my install? I just checked and there are no 3.4.1 updates listed
> for the SDK or platform.
> Is this a matter of a bit of lag for the udpate site or is it just not
> possible to update the platform itself using the update manager?
> Ian
Re: Updating to 3.4.1 (error launcher unable to locate shared library) [message #331899 is a reply to message #331863] Sat, 27 September 2008 06:10 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
>> that 3.4.1 has been released will I be able to use the update
>> mechanism to update my install? I just checked and there are no 3.4.1
>> updates listed for the SDK or platform.
>> Thanks,
>> Ian
I have different experiences:
* 3.4 RCP unmodified
automatic update detects 3.4.1
then started update
re-started workspace
all ok
quit
started again
all ok - now I git version 3.4.1
* 3.4 RCP - my working horse - updated all days with no problems
then started update
all ok
quit
started again
now immediatly I go the error (before selcting workspace)
The Eclipse executable launcher was unable to locate its companion
shared library
OSX 10.5.5
JDK 1.5
any ideas what gets wrong ?
ekke
Re: Updating to 3.4.1 (error launcher unable to locate shared library) [message #331901 is a reply to message #331899] Sat, 27 September 2008 10:48 Go to previous messageGo to next message
It seems that the launcher information is not updated properly.
Got to /Applications/eclipse/Eclipse.app/Contents/MacOS
and make sure the launcher library in eclipse.ini is set as follows
--launcher.library
../../../plugins/org.eclipse.equinox.launcher.carbon.macosx_ 1.0.101.R34x_v20080731
That worked for me!
cya
Michael
Re: Updating to 3.4.1 (error launcher unable to locate shared library) [message #331903 is a reply to message #331901] Sat, 27 September 2008 13:15 Go to previous messageGo to next message
> --launcher.library
> ./../../plugins/org.eclipse.equinox.launcher.carbon.macosx_1 .0.101.R34x_v20080731
> That worked for me!
> cya
> Michael
michael, thanks,
you're right that the information was not updated,
but it doesnt help.
....changed it, tried to start again... same error
then I tried to update my other 3.4.0 - its not RCP, its Modeling
update runs without errors, restarted workbench,
then many problems:
editor area empty, clicking on something was very slow,
couldn't quit using menu - had to kill eclipse
after restart same error as from my rcp - eclipse
thanks to TimeMachine I went back to the version before
there seems to be problems with my installations wether rcp
or modeling - auto-updateing to 3.4.1
all other updates since 3.4.0 comes out were never problematic
and using a plain 3.4.0 rcp or modeling and auto-updating also
did the job
think best is to make a clean install
ekke
Re: Updating to 3.4.1 (error launcher unable to locate shared library) [message #331907 is a reply to message #331903] Sun, 28 September 2008 05:56 Go to previous messageGo to next message
May not be related, but I'm not able to update either on Windows:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.help.base.source/osgi.bundle/3.3.101.M20080728_3 4x
org.eclipse.help.source/org.eclipse.update.feature/1.0.1.R34 x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat
org.eclipse.help.ui.source/osgi.bundle/3.3.101.M20080715_34x
org.eclipse.help.webapp.source/osgi.bundle/3.3.101.M20080805 _34x
org.eclipse.ui.forms.source/osgi.bundle/3.3.101.v20080708_34 x
org.eclipse.sdk.ide.launcher.win32.win32.x86/binary/3.4.0.M2 0080911-1700
Re: Updating to 3.4.1 (error launcher unable to locate shared library) [message #331923 is a reply to message #331907] Mon, 29 September 2008 12:43 Go to previous message
Opened bug for this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=248983
Previous Topic:Problem Installing plug-ins on Ganymede through P2 Update Manager on Windows Vista
Next Topic:CellNavigationStrategy doesn't seem to work with a TreeViewer
Current Time: Thu Jul 17 22:13:47 EDT 2025
Powered by FUDForum. Page generated in 0.08992 seconds
