Extending DeleteResourceAction [message #331859] |
Thu, 25 September 2008 09:58  |
Originally posted by: andreas-scharf.gmx.de
I have view using the CNF which currently does almost the same as the
Resource Explorer. In my special application I have dependent resources
and if the user deletes resource A the dependent resource B (which is a
file which only contains UI information) also should be deleted. I
thought of using my own MyDeleteResourceAction in which I execute 2
DeleteResourceActions (one to actually delete the resource the user
selected and one to delete the dependent UI information resource).
Is that approach applicable or is there another (better) way to do this?
Greetings,
Andreas
FUDForum. Page generated in 0.03742 seconds
