Home » Eclipse Projects » Eclipse Platform » Redirecting to eclipse.platform (was Re: In 3.4 SDK config.ini: what do these org.eclipse.* lines do
Redirecting to eclipse.platform (was Re: In 3.4 SDK config.ini: what do these org.eclipse.* lines do [message #331855] Thu, 25 September 2008 08:54 Go to next message
Originally posted by: nospam_kowalskilee.gmail.com
Hi, I didn't get any responses on eclipse.newcomer, so am adding
eclipse.platform to this thread.
Any info/specs for the lines org.eclipse.update.reconcile=false and
org.eclipse.equinox.simpleconfigurator.configUrl in config.ini file for
Eclipse SDK package?
Thanks!
Lee Anne wrote:
> I'm trying to migrate something I used to do in 3.3 to 3.4. I'm
> comparing the 3.3 config.ini file with the 3.4 one and am trying to
> understand the differences.
> What do the lines actually do or affect?:
> I've searched the 3.4 help, but get "Nothing found". :-)I tried the
> Eclipse Runtime options topic in the 3.4 help, and while it covers
> things like the osgi.* lines and eclipse.* lines, it doesn't have
> anything about those two org.eclipse.* lines in config.ini.
> I have searched in Google, and for org.eclipse.update.reconcile, I have
> a hit in the equinox-dev list where Pascal responded to an issue with a
> headless application and said it has to do with the "reconcilation
> behavior". I'd like to understand more about the reconciliation behavior
> and when would I set that line to "true" vs "false"? Is that covered
> somewhere?
> Thanks in advance! If there's a 3.4 help topic or other page that I've
> overlooked, please point me to it.
> Sincerely,
> Lee Anne
Re: Redirecting to eclipse.platform (was Re: In 3.4 SDK config.ini: what do these org.eclipse.* line [message #331871 is a reply to message #331855] Thu, 25 September 2008 16:20 Go to previous message
I'm not sure about the update.reconcile property, but the
simpleconfigurator.configURL property points to a bundles.info file
which lists which bundles should be installed and what their start
levels should be. This is then managed by p2 to controlled what is
running in the system.
You could compare the org.eclipse.equinox.simpleconfigurator and the
bundles.info to the old org.eclipse.update.configurator and platform.xml
-Andrew
> Thanks!
> Lee Anne wrote:
>> have a hit in the equinox-dev list where Pascal responded to an issue
>> with a headless application and said it has to do with the
>> "reconcilation behavior". I'd like to understand more about the
>> reconciliation behavior and when would I set that line to "true" vs
>> "false"? Is that covered somewhere?
>> Sincerely,
>> Lee Anne
Previous Topic:Eclipse 3.4 on Solaris 10 sparc
Next Topic:Adding a new static help topic
Current Time: Mon Jul 14 21:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.24377 seconds
