Home » Eclipse Projects » Eclipse Platform » Expression-bases Activities always disabled
Expression-bases Activities always disabled [message #331835] Wed, 24 September 2008 11:26 Go to next message
I am testing expression-based activities within a simple rcp application.
I oriented myself at the eclipse help section for activities. My problem
is, that the activity is always disabled. The expression seems not to be
evaluated as true.
My Plugin.xml (PluginA) looks like this:
<plugin>
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="de.cenit.play.rcp.commands.ShowQuestionCommand "
id="de.cenit.play.rcp.commands.ShowQuestionCommand"
name="Show Question">
</command>
</extension>
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="menu:actions">
<command
commandId="de.cenit.play.rcp.commands.ShowQuestionCommand"
style="push">
</command>
</menuContribution>
</extension>
<extension
point="org.eclipse.ui.activities">
<activity
id="de.cenit.play.rcp.commands.activities.ShowQuestionCommand "
name="ShowQuestionCommand">
<enabledWhen>
<with
variable="de.cenit.play.rcp.rights">
<iterate
ifEmpty="false"
operator="or">
<equals
value="de.cenit.play.rcp.commands.ShowQuestionCommand">
</equals>
</iterate>
</with>
</enabledWhen>
</activity>
<activityPatternBinding
activityId="de.cenit.play.rcp.commands.activities.ShowQuestionCommand "
isEqualityPattern="true"
pattern=" de.cenit.play.rcp.commands/de.cenit.play.rcp.commands.ShowQu estionCommand ">
</activityPatternBinding>
</extension>
</plugin>
The SourceProvider is registered in another plugin (Plugin B <- RCP
Plugin):
<plugin>
<extension
point="org.eclipse.ui.services">
<sourceProvider
provider="de.cenit.play.rcp.SourceProvider">
<variable
name="de.cenit.play.rcp.rights"
priorityLevel="workbench">
</variable>
</sourceProvider>
</extension>
</plugin>
And here is the source code of the SourceProvider:
public class SourceProvider extends AbstractSourceProvider {
private final static String SOURCENAME_RIGHTS =
"de.cenit.play.rcp.rights";
public Map getCurrentState() {
LinkedList<String> ids = new LinkedList<String>();
ids.add("de.cenit.play.rcp.commands.ShowQuestionCommand");
HashMap<String, List<String>> stateMap = new HashMap<String,
List<String>>();
stateMap.put(SOURCENAME_RIGHTS, ids);
return stateMap;
public String[] getProvidedSourceNames() {
return new String[] { SOURCENAME_RIGHTS };
My opinion is, that the activity should be enabled, but it is not. What
did I oversight?
Does anyone has an idea?
Best Regards
Adam
Re: Expression-bases Activities always disabled [message #331868 is a reply to message #331835] Thu, 25 September 2008 14:33 Go to previous messageGo to next message
Is it that you can see your actions menu, but you can't see the "Show
Question" menu item?
Is your getCurrentState() ever called? Is the code in the
EvaluationAuthority re-evaluating any expressions against your
de.cenit.play.rcp.rights variable? There doesn't appear to be anything
obviously wrong with your example.
PW
Paul Webster
Re: Expression-bases Activities always disabled [message #331882 is a reply to message #331868] Fri, 26 September 2008 08:02 Go to previous messageGo to next message
Alright I have got it partly.
At first some answers to the questions:
The "Commands" Menu is visible, but the "Show Question" menue item is not.
But it should be visible because of the provided source value.
ISourceProvider.getCurrentState() is called twice. But the concerning
variable is not reevaulated at startup automatically. Everythings seems to
be okay, when
IEvaluationService.requestEvaluation("de.cenit.play.rcp.rights ") is called
after ISourceProvider.getCurrentState() was called. The other possibility
is to force an evaluation with ISourceProvider.fireSourceChanged(0,
getCurrentState()).
My questions are now:
1. Why do I have to force the evaluation manually at startup?
2. What is the best practice to do 1.?
3. Is there a good way to get the instance of my ISourceProvider which is
declared in the plugin.xml?
Thank you for your replay. That already helps me a lot!
Best Regards
Adam
Re: Expression-bases Activities always disabled [message #331884 is a reply to message #331882] Fri, 26 September 2008 09:05 Go to previous messageGo to next message
> not. But it should be visible because of the provided source value.
> to be okay, when
> called after ISourceProvider.getCurrentState() was called. The other
> possibility is to force an evaluation with
> ISourceProvider.fireSourceChanged(0, getCurrentState()).
Adam, this might be a bug in eclipse (if we're filling in expressions
but then not updating them when we instantiate the source provider.
Please enter a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[Services]
It won't hurt anything to do the
IEvaluationService.requestEvaluation("de.cenit.play.rcp.rights "),
AFAICT, it just forces an extra evaluation.
Thanx,
PW
Paul Webster
Re: Expression-bases Activities always disabled [message #785094 is a reply to message #331884] Sat, 28 January 2012 07:59 Go to previous message
Hello!
I'm facing the same issue as the one described in this old post. Using a source provider and a variable for enabling/disabling a view or preferences, when debugging I see that reevalution is not done after MySourceProvider.getCurrentState()has been called.
What I see is that in ContextAuthority.sourceChanged() my activity is not in the Collection activationsBySourcePriority and moreover the program never gets into the branch if ((sourcePriority & (1 << i)) != 0) , so that even if it were there it would never be added to activationsToRecompute.
Evaluation is only done BEFORE the source provider is added and this has the consequence that the activity is not enabled and that I never see my view/preferences.
Can you help me please?
Guenther Mahr
Previous Topic:Can I have problem marks in the Resource Navigator icons?
Next Topic:programmatically call source format (CTRL+SHIFT+F)
Current Time: Sun Aug 31 03:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.03769 seconds
