Home » Eclipse Projects » Eclipse Platform » How to disable Welcome view when running/debugging eclipse plug-in
How to disable Welcome view when running/debugging eclipse plug-in [message #331807] Tue, 23 September 2008 06:21 Go to next message
When I run/debug an eclipse plug-in or when I run JUnit tests (JUnit
Plugin Test), the launched workbench starts really slow and oftentimes I
see timeout errors in the console. I was able to point the root cause to
the Welcome view that loads a lot of data including some data from the
internet!
I don't need this when debugging or running JUnit tests and I don't want
to have to create/save the runtime workspace just to make it run faster
(by removing the Welcome pages in the preferences of the runtime
workspace). I still want to be able to just debug or run the JUnit without
the need for an already configured runtime workspace.
The question is, is there a way to disable the Welcome view from loading
when I run/debug a plug-in or when I run JUnit plug-in tests?
BTW, I'm using Eclipse 3.3.3.
Francis
Re: How to disable Welcome view when running/debugging eclipse plug-in [message #331809 is a reply to message #331807] Tue, 23 September 2008 07:33 Go to previous messageGo to next message
You can remove the Welcome page appearing on the start-up of the Eclipse .
Import, org.eclipse.ui.intro.universal==>open the plugin.xml==>go to
extension section==>remove the extension named org.eclipse.ui.intro.
After Saving and Cleaning.
Replace the modified plugin into the Plugin directory of your eclipse.
The Welcome Page will Never Appear.
And if you want to remove this temporarily then simply keep this modified
plugin in your workspace .
Re: How to disable Welcome view when running/debugging eclipse plug-in [message #331829 is a reply to message #331809] Wed, 24 September 2008 07:12 Go to previous messageGo to next message
Thanks Bhasker. Your suggestion works. I'm just curious though, is there a
command line argument version of this (disabling the Welcome page)?
/Francis
Bhasker wrote:
Re: How to disable Welcome view when running/debugging eclipse plug-in [message #331913 is a reply to message #331829] Mon, 29 September 2008 05:00 Go to previous messageGo to next message
Hi Francis,
As far i think , there is no way to do the same via command line.
Bye.
Re: How to disable Welcome view when running/debugging eclipse plug-in [message #332000 is a reply to message #331913] Wed, 01 October 2008 09:13 Go to previous message
Bhasker wrote:
> Hi Francis,
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/reference/misc/runtime-options.html
You can create a plugin_customization.ini file and use the CLI to point
to it from your launch config dialog.
PW
Paul Webster
Previous Topic:Unable to register Search Extension to search extension point.
Next Topic:Extending DeleteResourceAction
Current Time: Tue Oct 28 21:42:29 EDT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
