| Re: widgets size in ManagedForm [message #331749] |
Fri, 19 September 2008 10:14 |
On 9/19/2008 12:06 AM, Lan wrote:
> Hi guys,
> I am still fuzz about how to control layouts. I have a wizard contains a
> ManagedForm and a MasterDetailsBlock in the MangedForm. The ratio of the
> block is set to 1:3. Whenever the details block show up, it is bigger
> than the details area so a horizontal scroll bar appears at the bottom
> of the details block. I can see there are a lot of white space in the
> details block... How do I make the details block resize itself to fit
> the details area? Which layout should I use???
First, I'm copying this to the eclipse.platform newsgroup because it is
not RCP-specific.
Second, it is very difficult to help with layout problems without a
runnable snippet that demonstrates the problem. There are just too many
variables at play when it comes to layouts that describing them
accurately in words is very difficult. If you provide a runnable snippet
(as in http://www.eclipse.org/swt/faq.php#whatisasnippet) that
demonstrates the problem, you're more likely to get useful help.
Eric
FUDForum. Page generated in 0.04194 seconds
