| disable cut/copy/paste on StyledText [message #331744] |
Fri, 19 September 2008 05:58  |
I have created a header partition in my editor and made it uneditable by
implementing verifyText() method of VerifyListener which is a listener on
the StyledText.
It is working perfectly (and does not allow any keyboard modifications to
the header) except that I am still able to cut a part of the header or
paste some text in the header.
How do I disable the cut/copy/paste actions in the partition ?
Thanks in Advance
Sheela
| Re: disable cut/copy/paste on StyledText [message #331758 is a reply to message #331744] |
Fri, 19 September 2008 15:20   |
Hi Sheela,
In the snippet below cut and paste are successfully vetoed. Copy still
happens, but this should not be a big problem since it does not modify the
StyledText's content. Does the snippet below work similarly for you? And
if so, can you change it in a way that makes it show your problem?
public static void main (String [] args) {
Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10,10,200,200);
shell.setLayout(new FillLayout());
StyledText text = new StyledText(shell, SWT.NONE);
text.setText("hihihihi");
text.addListener(SWT.Verify, new Listener() {
public void handleEvent(Event event) {
event.doit = false;
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Sheela " <sheela_kalyanpur@infosys.com> wrote in message
news:159b1ad8786d86425886e25b641abffc$1@www.eclipse.org...
> the StyledText.
> Thanks in Advance
> Sheela
FUDForum. Page generated in 0.05389 seconds
